michael.hamilton Posted August 15, 2013 Share Posted August 15, 2013 Please excuse this simple question from a newcomer. I use a Select controller with 4 locos. I use the "Select" button to cycle through the addresses. Somehow I have ended up with another address number which I would like to remove. Is there a simple way to remove one address number or will I have to reset the unit and re-enter the addresses I want. Link to comment Share on other sites More sharing options...
Rog RJ Posted August 15, 2013 Share Posted August 15, 2013 You can reset the Select and all the addresses in the stack will be wiped. When you next select a loco address it will be added back into the stack and you don't need to program the locos again as the decoder in the locos remembers it's own address. Link to comment Share on other sites More sharing options...
michael.hamilton Posted August 15, 2013 Author Share Posted August 15, 2013 Thank you. Link to comment Share on other sites More sharing options...
