AlexPW Posted August 20, 2013 Share Posted August 20, 2013 The info says transformer is rated at 1amp, does anyone have experience either way of running multi loco's or DDC sound loco's & power supplyissues.Is there a booster available for large layouts? Link to comment Share on other sites More sharing options...
Cowplain Posted August 20, 2013 Share Posted August 20, 2013 Hi Alex, I am a bit of a newcomer to the forum and I suppose RM, as most must be! Initially I ran 6 Locos on my layout under RM control with the provided eLink 1 amp power supply(12x4ft with quite a long 1in40 gradient) and I had no problems. I now use the 4 amp power supply that came with a Hornby power booster, purely because it was more convenient in the rather scruffy way I initially laid out my power inputs to the layout. I see no difference, but as a good old Naval Engineer I always look for more power! Link to comment Share on other sites More sharing options...
AlexPW Posted August 20, 2013 Author Share Posted August 20, 2013 Cowplain said: Hi Alex, I am a bit of a newcomer to the forum and I suppose RM, as most must be! Initially I ran 6 Locos on my layout under RM control with the provided eLink 1 amp power supply(12x4ft with quite a long 1in40 gradient) and I had no problems. I now use the 4 amp power supply that came with a Hornby power booster, purely because it was more convenient in the rather scruffy way I initially laid out my power inputs to the layout. I see no difference, but as a good old Naval Engineer I always look for more power! Link to comment Share on other sites More sharing options...
AlexPW Posted August 20, 2013 Author Share Posted August 20, 2013 Hi, Thanks for the quick reply,can I just comfirm that you were running the loco's(more than one) at the same time rather than just having six loco's on the layout at the same time? My dad & myself used to run up to 4 loco's on the old track as it was 3 loops & 2 fiddle yards with DC. We have fitted the loco's with decoders and the new layout is 22ft by 3ft. Just have to decide when to jump on to the elink/RM platform (once some of the bugs have been ironed out). Looks like dad needs to exercise his credit card! Thanks Alex Link to comment Share on other sites More sharing options...
Fishmanoz Posted August 20, 2013 Share Posted August 20, 2013 Alex, typically, the 1 amp supply will run 3 locos actually running at the same time, and power some accessories like points. For more than that, you get the alternative 4 amp power pack, not a booster which is a separate item for very large layouts split into separate power districts which are isolated from each other. Link to comment Share on other sites More sharing options...
billhayleytwo Posted August 22, 2013 Share Posted August 22, 2013 Are you aware that e link does not have an accessory socket? Unlike the Elite and Select that do. I have the 4 amp transformer. I discovered this when I went to programme an accessory decoder that required a seperate power supply as well as DCC input. Link to comment Share on other sites More sharing options...
Fishmanoz Posted August 22, 2013 Share Posted August 22, 2013 Hi BH2, yes I was. Simple reason from the Hornby viewpoint. One assumption is that you will want to run accessories DCC through RM not DC. And all Hornby accessory decoders only require track connection. Link to comment Share on other sites More sharing options...
AlexPW Posted August 22, 2013 Author Share Posted August 22, 2013 Thanks, I'll look into what & how the accessories socket works (just out of interest), but I have nearly 50 points, which are manual. When I get around to automating them it will be a case of the few ones that are really difficaults to reach (at the back of the layout) and I assumed that I would DCC them through RM (as the functionallity is already in RM). As its a out & back (no loops)layoy I'll wait until loco detection arrives & budget allows before automating the lot! Link to comment Share on other sites More sharing options...
