victorrichard Posted August 30, 2013 Share Posted August 30, 2013 My r8247 point decoder stops working if a train short circuits over a set of points. All 4 points on the decoder stop working. I then have to disconnect all the wires and remove from the board to reprogramme. This only happens on the same decoder all the others decoders still work ok even if a train short circuits on another set of points. Please help Link to comment Share on other sites More sharing options...
Fishmanoz Posted August 30, 2013 Share Posted August 30, 2013 This is not supposed to happen, although clearly it does from time to time. If less then a year old, return to the shop or Hornby for replacement. Link to comment Share on other sites More sharing options...
St1ngr4y Posted August 30, 2013 Share Posted August 30, 2013 Hi, Have a look at this thread from the DCC Forum: "R8247 Acc Decoder Stopped Working". Maybe a Bus Filter is what you need. Ray Link to comment Share on other sites More sharing options...
victorrichard Posted September 2, 2013 Author Share Posted September 2, 2013 Fishmanoz said: This is not supposed to happen, although clearly it does from time to time. If less then a year old, return to the shop or Hornby for replacement. Thanks for your info I am going to try a power bus suppressor first Link to comment Share on other sites More sharing options...
victorrichard Posted September 2, 2013 Author Share Posted September 2, 2013 St1ngr4y said: Hi, Have a look at this thread from the DCC Forum: "R8247 Acc Decoder Stopped Working". Maybe a Bus Filter is what you need. Ray I will try a Power Bus Suppressor see if it works at about £8 pound is better than £40 for a new one Thanks Link to comment Share on other sites More sharing options...
Fishmanoz Posted September 2, 2013 Share Posted September 2, 2013 Buying a resistor and capacitor will be a lot cheaper then £8 if you can solder too. Link to comment Share on other sites More sharing options...
victorrichard Posted September 3, 2013 Author Share Posted September 3, 2013 Fishmanoz said: Buying a resistor and capacitor will be a lot cheaper then £8 if you can solder too. Good Idea Thanks Link to comment Share on other sites More sharing options...
