midway Posted August 30, 2013 Share Posted August 30, 2013 advice please re removing body of above and how to stop breaks rubbing on wheels.thanks. Link to comment Share on other sites More sharing options...
58001 Posted September 1, 2013 Share Posted September 1, 2013 There is a clip at the rear of the locomotive which is visible from the outside just above the buffer beam. Gently ease the rear of the locomotive away from the chassis by pushing in the clip or levering the back of the body. The brakes are moulded parts of the chassis so should not touch the wheels. If they are then the wheels are not properly located. This is a common problem with 0-6-0 locos where all six must be aligned otherwise the coupling rods will pull them off axis. Link to comment Share on other sites More sharing options...
midway Posted September 1, 2013 Author Share Posted September 1, 2013 58001 said: There is a clip at the rear of the locomotive which is visible from the outside just above the buffer beam. Gently ease the rear of the locomotive away from the chassis by pushing in the clip or levering the back of the body. The brakes are moulded parts of the chassis so should not touch the wheels. If they are then the wheels are not properly located. This is a common problem with 0-6-0 locos where all six must be aligned otherwise the coupling rods will pull them off axis. Link to comment Share on other sites More sharing options...
midway Posted September 1, 2013 Author Share Posted September 1, 2013 thanks for the info 58001,I think I had better get a wheel gauge Link to comment Share on other sites More sharing options...
58001 Posted September 1, 2013 Share Posted September 1, 2013 While it is always worth checking the back to back, I was trying to refer to the coupling rods being misaligned. If just one wheel is slightly advanced with respect to the others on the same side this can lead to at least a waddle or at worst a seizing of the axles. Link to comment Share on other sites More sharing options...
Fishmanoz Posted September 1, 2013 Share Posted September 1, 2013 Google wheel quartering and you'll see what 58001 means, and how to fix it. Link to comment Share on other sites More sharing options...
58001 Posted September 2, 2013 Share Posted September 2, 2013 Thank you for providing the technical term, Flashman! Link to comment Share on other sites More sharing options...
