Lindsay_C Posted September 19, 2013 Share Posted September 19, 2013 Just purchased a new DCC set that includes the new e-link controller and Railmaster software. I simply cannot get this to work. Installed the RM software (including updates) and setup the e-link box and required COM port, etc. All went well, no problem. Setup the rails, etc and connected the power. Started Railmaster, which seems to communicate with the e-link unit. Also noticed a green DCC controller icon at top right of screen, which displays a "DCC Controller active" message when you place the mouse cursor over it. Tried to start the loco - nothing happens (it was already set up in RM as ID 0003), so all should work, but nothing. Checked all the usual stuff, connections, etc, still nothing. Also checked power was being delivered to the track, got 25V reading on meter. Tried reboot, resetting, changing COM port, all I can think of, still not working. Also noted that all COM settings in RM are correct and match those in Ports section of XP device manager. One wierd thing, the loco started at full speed for a few seconds on the track when I booted up and connected after a few attempts, but then went dead again and will not respond. So think the loco is working, just can get no response to control. Thinking a faulty e-link controller. Need help. Lindsay Link to comment Share on other sites More sharing options...
Fishmanoz Posted September 19, 2013 Share Posted September 19, 2013 Lindsay, from your description, you seem to know what you are doing as all your setup stuff seems right. Decoders come default with address 03 or 00003 (same thing as far as RM is concerned, although stored differently in the decoder). So straight out of the box, when you set up a loco in RM, it should have the default 03 ID and run straight away. A simple way to check things is to look at your manual on reading CVs and see what you get. It is likely it will tell you they are all 255, which means it can't read them at all. Next thing to do is to email RM Support from within the Help section of RM. if they agree the eLink is faulty, they will replace it for you. And DCC locos taking off flat out is a well known problem. It means the decoder got a bad DCC signal, interpreted it to be DC not DCC and, as full rail volts are present all the time on DCC, it applied full throttle. The DC feature can be turned off in CV29 and it is recommended you do so, once you have a functioning eLink connection. Again, the manual tells you the number to add to CV29 to do this. CV29 is different to other CVs in that each bit in its word controls something different. So if you understand binary maths at all, it will be clear that to change the bit 0 feature, you would add 1 to the value of the CV, for bit 1, add 2, for bit 3 add 4, bit 4 add 8, etc. Link to comment Share on other sites More sharing options...
Lindsay_C Posted September 20, 2013 Author Share Posted September 20, 2013 Thanks for your reply Fishmanoz. Actually got it working last night. I noticed that there were no CV values recorded in the RM application for the loco that came with the set. I connected the e-link unit to the track using the "Prog" connection and managed to read the CV's from the loco into RM, there were not very many so it only took around 10 minutes. I saved this info to the locos settings in RM. Then I hooked the e-link back up to the "Track" connections, tried it and it worked, the loco is running OK now. Not sure if what I did was by the book, but it worked for me. So far all is now running smoothly. Thanks for helping, no doubt will be back again. Link to comment Share on other sites More sharing options...
Fishmanoz Posted September 20, 2013 Share Posted September 20, 2013 Still sounds like you are doing the right thing, I should have mentioned the need to use the programming output. Link to comment Share on other sites More sharing options...
