Bad.back.buick Posted October 12, 2013 Share Posted October 12, 2013 Hi, Having waited for 3 weeks to get my 3 loco's back from digitrains I was hoping I could start running them on my new layout (I'm new to dcc and coming back to modelling after a 30 year break). The railmaster an elink all set up and apparently working, all instructions followed, placed the first train on the track and...... Nothing. Same on the other 2 loco's, I've set the loco's up and have a dedicated programming track with the wires soldered onto the track. Place a loco on the prof track and try to read the decoder and I get a message that says error, again same on all 3. I've checked all the system settings and they are correct, I've deleted all the loco's and tried again. The main track is getting approx 21 volts ac. Has anyone got any ideas as to what I'm doing wrong? Thanks Link to comment Share on other sites More sharing options...
Fishmanoz Posted October 13, 2013 Share Posted October 13, 2013 If you are getting an error reading CVs on 3 locos, it sounds like there is no connection between RM and the track. So let's start with the simple things. I take it when you start RM that it finds the eLink? And when you go into device manager and check the assigned com port, it is the same as the port set for the controller in RM? Get back to us with those answers and if all ok, we can see where to go next. Link to comment Share on other sites More sharing options...
Fishmanoz Posted October 13, 2013 Share Posted October 13, 2013 Oh, and you are running as administrator? Link to comment Share on other sites More sharing options...
Bad.back.buick Posted October 13, 2013 Author Share Posted October 13, 2013 Fishmanoz said: Oh, and you are running as administrator? Link to comment Share on other sites More sharing options...
Bad.back.buick Posted October 13, 2013 Author Share Posted October 13, 2013 Hi, in answer to your questions: Yes I believe the RM does find the elink (the symbol in the top right says dcc controller active). Yes the port is the same and the settings in device manager and RM are set the same. Yes I am running as the administrator Link to comment Share on other sites More sharing options...
Fishmanoz Posted October 13, 2013 Share Posted October 13, 2013 Good start, sounds like your set up is ok. With this correct and getting nothing from the programming track, you may have a faulty eLink. So I suggest you email RM Support from within the Help window of RM and describe your problem to them, including telling them the answers to the questions to show you are correctly set up, and see what they say. If they agree it is faulty, they will replace it for you. Link to comment Share on other sites More sharing options...
Bad.back.buick Posted October 13, 2013 Author Share Posted October 13, 2013 Fishmanoz said: Good start, sounds like your set up is ok. With this correct and getting nothing from the programming track, you may have a faulty eLink. So I suggest you email RM Support from within the Help window of RM and describe your problem to them, including telling them the answers to the questions to show you are correctly set up, and see what they say. If they agree it is faulty, they will replace it for you. Link to comment Share on other sites More sharing options...
Bad.back.buick Posted October 13, 2013 Author Share Posted October 13, 2013 Hi, Thanks for the help and advice. I'll give that a go and see how I get on. Cheers Link to comment Share on other sites More sharing options...
Bad.back.buick Posted October 14, 2013 Author Share Posted October 14, 2013 Post a new reply... Link to comment Share on other sites More sharing options...
Bad.back.buick Posted October 14, 2013 Author Share Posted October 14, 2013 Hi, thanks for your help. I contacted the help desk and they pointed out that I had the dcc controller set to elite instead of elink. Although I felt bit of an a##e the joy of seeing 3 trains running round outweighed my embarrassment! Many thanks again.:-) Link to comment Share on other sites More sharing options...
Fishmanoz Posted October 14, 2013 Share Posted October 14, 2013 We all make silly mistakes like that sometimes bbb. Better a temporary red face and the locos working than the alternative. Interesting outcome though for those who say that in practice eLink is just Elite without knobs. Clearly there are more differences than that in the firmware in each, and/or the drivers for each are incompatible with the other. Link to comment Share on other sites More sharing options...
