PeterMcGowan Posted October 22, 2013 Share Posted October 22, 2013 Hi All I am hoping somebody can help. I have a DCC Layout with an Elite control with a select connected to the elite. I have 2 x Points accessory Decoders. However every now and then the points decoders just seem to loose the programming. I will program all 4 points and they work perfectly for a while and then just stop working. I have to then re-connect to the programming track and re-program. However the locos that I have programed always remain and I have never had to re-program these. any assistance would be appreciated Thanks Peter Link to comment Share on other sites More sharing options...
Fishmanoz Posted October 22, 2013 Share Posted October 22, 2013 Unfortunately, this is known to happen from time to time. If you are getting momentary shorts on your layout, it is more likely, so check and see if that is a possibility. If you are running a DCC bus, fitting bus terminators may also help. Link to comment Share on other sites More sharing options...
