Into_TheCatalyst Posted November 1, 2013 Share Posted November 1, 2013 Hello, I am looking into upgrading my layout to DCC and I have a Hornsby turntable but want to use ez-command control, science the DCC wiring goes straight from the decoder to the track instead of going through the controller like the analouge way, I was wondering if the ez-command would just pick it up like a normail loco. Link to comment Share on other sites More sharing options...
idlemarvel Posted November 1, 2013 Share Posted November 1, 2013 If you want to drive the Hornby turntable from a DCC controller then you have to fit a standard loco decoder as per these instructions: https://www.hornby.com/hornby-dcc/decoder-installation-guides/turntable-conversion/ Then you control the turntable just like a normal loco. Link to comment Share on other sites More sharing options...
Into_TheCatalyst Posted November 1, 2013 Author Share Posted November 1, 2013 Yes, thats what I thought,but I just wanted to see it it does work with ez-command, thanks Link to comment Share on other sites More sharing options...
Fishmanoz Posted November 1, 2013 Share Posted November 1, 2013 Ez command is just the blue box company's DCC controller and said to be NMRA compatible like most other DCC gear, all of which allow connections of loco and accessory decoders directly to track,which is of course the same as connecting to the controllers track output anyway. So, as idle marvel says above, the Hornby TT will work this way. However please note a number of older threads in here by searching TT or turntable which give alternative methods of DCC conversion of the DCC track without using the inferior method suggested by Hornby of removing the clips on the bridge rails. It is far better to have isolated track outputs only where needed rather than doing this. Then it would be better still to have a TT designed for DCC running in the first place, like some other brands. Link to comment Share on other sites More sharing options...
