Iangwarsop Posted November 3, 2013 Share Posted November 3, 2013 The manual does not mention the 'change loco ID' button from this screen - why not or did I miss something. Also - what is the 'Loco Detection System ID' value supposed to be is it the same as Loco ID - can someone explain what this is supposed to be here and what it means? I have two locos and one is running ok on ID 0003 but I have failed to change its ID from this screen and the other loco is sitting waiting until I have successfully changed it. Link to comment Share on other sites More sharing options...
Fishmanoz Posted November 4, 2013 Share Posted November 4, 2013 I think you missed it lw, it's on pp42-44 of the v1.53 manual in full detail. Within the Loco Setup window, you can use the Loco Settings button to change all CVs, including lower number IDs in CV1. For all IDs including long addresses, use the Change Loco ID button as you mentioned above, covered on p44. Link to comment Share on other sites More sharing options...
Iangwarsop Posted November 4, 2013 Author Share Posted November 4, 2013 By the way I love Fish - I could eat it 7 days a week if my wife would let me. Thanks - The above was my first post and will check back later when I have checked my manuals version. Link to comment Share on other sites More sharing options...
Graskie Posted November 4, 2013 Share Posted November 4, 2013 You're only supposed to eat fish on a Friday! Link to comment Share on other sites More sharing options...
Fishmanoz Posted November 4, 2013 Share Posted November 4, 2013 Try telling the fish that! Link to comment Share on other sites More sharing options...
Fishmanoz Posted November 4, 2013 Share Posted November 4, 2013 By the way lw, won't matter the manual version, the detail will be the same, only the page numbers might change a little. But assuming you have updated to the latest version of RM, the latest manual should be on your desktop. Link to comment Share on other sites More sharing options...
Iangwarsop Posted November 5, 2013 Author Share Posted November 5, 2013 Hi folks. I have re-read the manual (now v1.53) - still not sure it explains everything on the Loco Definition screen clearly! Progress on changing Loco ID/address. Failed on Loco Definition screen. Failed to read cv's as on page 44 etc therefore could not change ID number. Contacted support through Railmaster and explained how I had changed cables around to check cables were both OK. Also checked Program track OK. They have adviced me about following - Dear Ian Try one more thing. Although you are using version 1.53 of RailMaster can you dowload the latest setup file from www.powerpos.com/rail-master/rm_setup153.exe and run that to install RailMaster over your existing one, then try the loco programming again. I will do this tomorrow but in the meantime I re-connected my Dynamis Pro system that I had never programmed on and I have successfully changed one of the loco ID's with no problems. Did not try to read any other cv's but don't want to change anything else at present. I still desperately want the Railmaster/elink route to work as I love having it on a laptop with everthing else clearly seen. PS Been out for a meal tonight - guess what I had for the main course? Anyone in the forum with username with 'apple pie' or 'custard' - eight days a week for this. Link to comment Share on other sites More sharing options...
