olly Posted December 8, 2013 Share Posted December 8, 2013 I have just found in my spares box a hornby class 08 DCC 21 pin sound chip . I have fitted it to a blue box class 411 cep but can't get the lights to work do these decoders have a lighting function ? Link to comment Share on other sites More sharing options...
olly Posted December 8, 2013 Author Share Posted December 8, 2013 title should say spare dcc decoder . why is there no edit function ? Link to comment Share on other sites More sharing options...
Fishmanoz Posted December 8, 2013 Share Posted December 8, 2013 Lights are a standard function on decoders. Forward lights are the white wire, reverse yellow and the blue the common positive. Link to comment Share on other sites More sharing options...
Flashbang Posted December 8, 2013 Share Posted December 8, 2013 Hi There are no wires on a 21 pin decoder. Does the class 411 have working lights? If so, did they work on DC or with a non sound 21 pin decoder? Link to comment Share on other sites More sharing options...
olly Posted December 8, 2013 Author Share Posted December 8, 2013 Flashbang said: Hi There are no wires on a 21 pin decoder. Does the class 411 have working lights? If so, did they work on DC or with a non sound 21 pin decoder? yes the 411 has lights and they do work on DC .trying to save some money by using the 08 chip .it will run ok with this but can't get the lights on Link to comment Share on other sites More sharing options...
olly Posted December 8, 2013 Author Share Posted December 8, 2013 not sure about a non sound 21 pin chip don't have one to try Link to comment Share on other sites More sharing options...
Fishmanoz Posted December 8, 2013 Share Posted December 8, 2013 If in fact the decoder is direct plug so no wires as Flashbang suggests, then take a look at http://www.brian-lambert.co.uk/DCC.html#Basic to find the pin configurations, with the light function pins being 7 and 8 and the common 16. You will need to have these connected to your lights. Exact wiring arrangements for them can also be found on that Brian Lambert site. Link to comment Share on other sites More sharing options...
