PJ_model_trains Posted December 18, 2013 Share Posted December 18, 2013 I am experiencing problems reading CV's but not all loco's? I have checked several and wrote to a loco also but am having problems with a Class 6P Patriot 4-6-0 45504 "Royal Signals" I have checked contacts, added extra weight to the loco when reading CV's but keep getting error... repeating. Has anyone any suggestions please? Link to comment Share on other sites More sharing options...
Fishmanoz Posted December 18, 2013 Share Posted December 18, 2013 First make sure your programming track is spotless, then check for clean wheels and properly adjusted pickups. Given it is specific to a loco, logic says it must be a loco problem. Link to comment Share on other sites More sharing options...
Graskie Posted December 18, 2013 Share Posted December 18, 2013 I have one of those, PJ, will check it out and let you know what mine does. I do know that B*chmann loco CVs such as this couldn't be read at one time on my Elite. I used to get XXXX. Link to comment Share on other sites More sharing options...
Fishmanoz Posted December 18, 2013 Share Posted December 18, 2013 Early Bmann decoder not fully NMRA compatible possibly? Link to comment Share on other sites More sharing options...
PJ_model_trains Posted December 18, 2013 Author Share Posted December 18, 2013 Fishmanoz said: Early Bmann decoder not fully NMRA compatible possibly? This is a brand new loco. It has an 8 pin NMRA/NEM socket with decoder installed. I guess it is it something to do with the chip in this loco as it is not passing CV7 Link to comment Share on other sites More sharing options...
PJ_model_trains Posted December 18, 2013 Author Share Posted December 18, 2013 I have restarted laptop. Opened Railmaster and it requested a different baud rate. I changed this to 115200 as requested and tried again. Error again, different message. Check connections, done. Also says possible CV being read does not support reading ??? It is brand new? After error at CV 7 it now says unobtainable it then tried CV 1 and gave usual errors. I tried Loco on live track but it will not run. I am assuming it is on 0003 but nothing happening. The reason I was checking CV was to find loco DCC ID. I will have to telephone eHattons tomorrow. Link to comment Share on other sites More sharing options...
PJ_model_trains Posted December 18, 2013 Author Share Posted December 18, 2013 I have switched on the point switch icon, then the loco in the box and it says in the switch icon 0003 so I assume the loco is set on 0003 Link to comment Share on other sites More sharing options...
Fishmanoz Posted December 19, 2013 Share Posted December 19, 2013 You don't have to check the ID of a new loco, it will always be 03. That is why you change all of your existing loco IDs so as to leave 03 vacant for each new one as you add it. Not running either? Again, a mechanical connection problem. It isn't perhaps one that will not run unless tender attached, and you haven't attached it. Or tender is attached and causing a short from bent contacts? Try it without if won't run with, and vice versa. And check pickup contacts to wheels. If nothing obvious, return it to supplier. Link to comment Share on other sites More sharing options...
Graskie Posted December 19, 2013 Share Posted December 19, 2013 Tested mine, PJ. I can read CVs on Elite direct or from RM. Link to comment Share on other sites More sharing options...
Fishmanoz Posted December 19, 2013 Share Posted December 19, 2013 Sorry to bang on - it is a physical connection problem causing either an open circuit (most likely) or short circuit in the loco with/without the tender. If you want to go further than I have suggested above and are comfortable with removing the loco body before returning, check for broken wiring, decoder not fully seated or pushed in too far causing a short below, or even a blown decoder with black/burnt components in it. Link to comment Share on other sites More sharing options...
PJ_model_trains Posted December 19, 2013 Author Share Posted December 19, 2013 Fishmanoz said: You don't have to check the ID of a new loco, it will always be 03. That is why you change all of your existing loco IDs so as to leave 03 vacant for each new one as you add it. Not running either? Again, a mechanical connection problem. It isn't perhaps one that will not run unless tender attached, and you haven't attached it. Or tender is attached and causing a short from bent contacts? Try it without if won't run with, and vice versa. And check pickup contacts to wheels. If nothing obvious, return it to supplier. Testing done on the straight not on bends. Tender is attached all the time. I will contact eHattons, supplier, when they open this morning. Link to comment Share on other sites More sharing options...
PJ_model_trains Posted December 19, 2013 Author Share Posted December 19, 2013 Graskie said: Tested mine, PJ. I can read CVs on Elite direct or from RM. Thanks Graskie, I saw some had problems with CV's with RM 1.54 but this seems to be fixed so didn't expect problems with this loco, being brand new also. Link to comment Share on other sites More sharing options...
PJ_model_trains Posted December 19, 2013 Author Share Posted December 19, 2013 Supplier says it sounds as though the loco is faulty and have asked me to return it. So I won't be getting 'steamed up until after the new year' Not to worry I have my Class 37 with sound and lights plus another seven locos and track building to keep me quiet in between main holiday days and time with family. Thanks everyone for your help this year. Link to comment Share on other sites More sharing options...
Fishmanoz Posted December 19, 2013 Share Posted December 19, 2013 PJ_model_trains said: Testing done on the straight not on bends. Tender is attached all the time. I will contact eHattons, supplier, when they open this morning. PJ, you misunderstood me here. I wasn't talking about straights or curves but the electrical contacts under the tender post that take the current from the tender pickups through to the loco. These contacts can sometimes be bent causing shorts. You can prove if this is the case by removing the tender as I suggested. If it works without tender, then bent contacts is your problem. Link to comment Share on other sites More sharing options...
Fishmanoz Posted December 19, 2013 Share Posted December 19, 2013 I don't believe that CVs was anything to do with your problem, other than a symptom of the real problem. I could try to put a loco on the track and completely miss putting the wheels on the rails. If I tried to read the CVs, it would fail, but CV reading is clearly not the problem. Link to comment Share on other sites More sharing options...
PJ_model_trains Posted December 19, 2013 Author Share Posted December 19, 2013 Fishmanoz said: PJ_model_trains said: Testing done on the straight not on bends. Tender is attached all the time. I will contact eHattons, supplier, when they open this morning. PJ, you misunderstood me here. I wasn't talking about straights or curves but the electrical contacts under the tender post that take the current from the tender pickups through to the loco. These contacts can sometimes be bent causing shorts. You can prove if this is the case by removing the tender as I suggested. If it works without tender, then bent contacts is your problem. Thanks for explaining in more detail. I spoke with supplier and have returned the loco today. Link to comment Share on other sites More sharing options...
