Bahnhof Mersch Posted December 26, 2013 Share Posted December 26, 2013 I would appreciate advice on the following, please: I have migrated from using my Select to using RM with the E-link interface. No problems installing and setting up locos. Do I presume that I have to re-program all my points decoders, which were set up starting 61 etc. as per the Select instructions? Secondly I have the Hornby turntable, which I have converted to DCC with a loco decoder. When I construct my layout in RM and click-in in the turntable, how do I tell RM how to identify the turntable? In Select language, it was identified as loco no 11. I've read the very helpful manual, but it seems to presume that you have an Elite and are familiar with its ways, not a Select. Many thanks in anticipation. Link to comment Share on other sites More sharing options...
HornbyRailMasterSupport Posted December 26, 2013 Share Posted December 26, 2013 You do not have to reprogram your accessory decoders. Simply use the existing point address numbers when designing your track plan. Full details are in the RailMaser PDF guide in the track design setion. RailMaster supports turntables using loco decoders and this is easy enough to set up, again in the track design screen. Again, details of how to set up and operate a turntable are in the guide. To fine-tune your turntable speed and stopping points you may need to alter settings in the RailMaster.ini file. Details are in the PDF guide. The guide does not refer to the Select as this controller cannot be controlled through RailMaster. References to Elite procedures in the guide are deliberately minimal as RailMaster is designed for computer operation and therefore the Elite would be redundant as a human-interface controller. Link to comment Share on other sites More sharing options...
Bahnhof Mersch Posted December 26, 2013 Author Share Posted December 26, 2013 Thank you. I couldn't quite figure out how to identify the turntable from the PDF guide, which I've read from cover to cover twice , but no doubt it will become clear when I start the design! I'm pleased I haven't got to re-program 10 decoders! Thanks again. Link to comment Share on other sites More sharing options...
PJ_model_trains Posted December 26, 2013 Share Posted December 26, 2013 HornbyRailMasterSupport said: You do not have to reprogram your accessory decoders. Simply use the existing point address numbers when designing your track plan. Full details are in the RailMaser PDF guide in the track design setion. RailMaster supports turntables using loco decoders and this is easy enough to set up, again in the track design screen. Again, details of how to set up and operate a turntable are in the guide. To fine-tune your turntable speed and stopping points you may need to alter settings in the RailMaster.ini file. Details are in the PDF guide. The guide does not refer to the Select as this controller cannot be controlled through RailMaster. References to Elite procedures in the guide are deliberately minimal as RailMaster is designed for computer operation and therefore the Elite would be redundant as a human-interface controller. Well done Hornby, you have done a wonderful job over the Christmas holiday period. Link to comment Share on other sites More sharing options...
