Train Kid1707817815 Posted August 10, 2011 Share Posted August 10, 2011 Hi,I have recently downloaded the trial version of railmaster in order to see what it was like. Near the end of the installation the message:C:Windows/System32/msvbvm60.dllAn error occurred whilst trying to replace the existing file:DeleteFile Failed; code 5.Access is denied.I work on 64bit Vista and I have tried to run as an administrator and the message still appears.Any help would be appreciatedOwen Link to comment Share on other sites More sharing options...
Hornby Customer Care Posted August 10, 2011 Share Posted August 10, 2011 RailMaster use OCX files and I believe this message is associated with this. RailMaster also installs OCX files, but they may already reside on some systems. If RaiMaster asks the user if they want to overwrite these files they should answer yes because the ones we supply will always be up-to-date.The MSCOMM32.OCX is the Windows comm port handler, which allows RailMaster to talk to the Elite.The MSINET.OCX file is the Windows Internet control, which allows RailMaster to do activations, deactivations, help requests and download program updates.Both of these files are actually Microsoft files which we include on the CD-Rom to ensure users have the latest versions. They are also both critical to the operation of RailMaster.If you get any problems at all with "missing OCXs relating to MSINT or MSCOMM or indeed any other OCX files the solution is this:-1. Uninstall RailMaster2. Use Start=Run and type in the command "regsvr32 /u /s MSINET.OCX" (or whatever the name of the OCX is so for you iot would be msvbvm60.dll) and press Enter.3. Reinstall RailMaster and the problem will be solvedRemember to right-click on the setup program on the CD and "Run as administrator" especially on Windows Vista and Windows 7 systems.This problem related to old installations of Microsoft Visual Basic which are on some systems. Link to comment Share on other sites More sharing options...
LMSTim Posted August 12, 2011 Share Posted August 12, 2011 The specific solution for this one is:-1. Uninstall RailMaster you can backup .pln, .prg and resource.mdb first if you wish - plans, programs and locos, if you have created any2. Click on Start then Run and type in "regsvr32 /u /s MSVBM60.DLL" and press Enter.3. Use Windows Explorer to navigate to the C:\Windows\System32 folder and change the name of the file "msvbm60.dll" to "msvbm60.old".4. Install RailMaster again and you should not get any problems. Link to comment Share on other sites More sharing options...
Train Kid1707817815 Posted August 16, 2011 Author Share Posted August 16, 2011 LMSTim said:The specific solution for this one is:-1. Uninstall RailMaster you can backup .pln, .prg and resource.mdb first if you wish - plans, programs and locos, if you have created any2. Click on Start then Run and type in "regsvr32 /u /s MSVBM60.DLL" and press Enter.3. Use Windows Explorer to navigate to the C:\Windows\System32 folder and change the name of the file "msvbm60.dll" to "msvbm60.old".4. Install RailMaster again and you should not get any problems.msvbvm60.dll or msvbm60.dll do not exist in my windows system 32 folder. Should they be or do you know any good software which will create them? Link to comment Share on other sites More sharing options...
LMSTim Posted August 16, 2011 Share Posted August 16, 2011 In that case, it must be a secutory issue with writing that particular file.When you installed did you definitely right-click on the setup.exe file and "Run as administrator"?Did you do step 2 of the above list?Even if you couldn't find the file to delete, did you try reinstalling again? Link to comment Share on other sites More sharing options...
Train Kid1707817815 Posted August 16, 2011 Author Share Posted August 16, 2011 I found some software that creates one and created one, followed you instruction and the problem still occurs. Link to comment Share on other sites More sharing options...
Train Kid1707817815 Posted August 16, 2011 Author Share Posted August 16, 2011 I ran as admin and set it to run in compatibility mode with xp Link to comment Share on other sites More sharing options...
Train Kid1707817815 Posted August 16, 2011 Author Share Posted August 16, 2011 Did you mean msvbvm60.dll or msvbm60.dll? Link to comment Share on other sites More sharing options...
