MatthewCarty Posted December 29, 2013 Share Posted December 29, 2013 I have run my layout with the Select controller and a Reverse Loop Module installed for a while, and have recently upgraded to the Elink and Railmaster combination. I have Railmaster set up and working, however when I try and run locomotives over the isolated section the track short circuits. I have tried switching the reverse loop module between the options of Select and Elite, however it doesn't seem to make a difference. Any suggestions are much appreciated! Link to comment Share on other sites More sharing options...
Fishmanoz Posted December 29, 2013 Share Posted December 29, 2013 I would have thought it should operate as you describe using the Elite setting. But as it doesn't, try emailing RM Support from within the Help window of RM and see wha they have to say. They are very responsive and helpful. Link to comment Share on other sites More sharing options...
