stewart166 Posted January 8, 2014 Share Posted January 8, 2014 i have RM and e-link with the select controller now i was wanting to know if i am going to be able to use my handheld device because i am going to buy the full upgrade of the handheld device app can someone tell me if this is going to work thanks for the help Link to comment Share on other sites More sharing options...
Fishmanoz Posted January 8, 2014 Share Posted January 8, 2014 The answer is yes as just posted on your other thread. By the way, you can't actually use Select with an RM setup, your controller is eLink. You should select the eLink in RM Setup window. I know Select shows in there but there is currently no way to connect it to RM. Even if you could, Select's limitations would throttle you from being able to get the full power of RM. Link to comment Share on other sites More sharing options...
