Bunsen Posted January 21, 2014 Share Posted January 21, 2014 Hi I am just trying out the Demo version of Railmaster.I have installed it no problem and designed by own layout ok.I have run two Hornby locos Ok ,one of them is an Hornby sound loco that works fine,including all sound functions..I wanted to test a non- Hornby sound loco. I have deleted one of the Hornby locos and added the name of the non Hornby one in the control panel I have set speeds for it and it runs ok..I have set 6 sounds including sound on/off.I cannot get any sound to work from the railmaster control panel for this Loco.Sound works ok through Elite. Any advice welcome.Many thanks. Link to comment Share on other sites More sharing options...
St1ngr4y Posted January 22, 2014 Share Posted January 22, 2014 Hi, As no one else has replied, the only thing I can think of is to reset the Elite, only, of course, if you haven't stored any loco details in the Elite, otherwise these would be lost. Other than that, I can't think of anything else other than contact HRMS. Is it a Loksound decoder in the loco? Ray Link to comment Share on other sites More sharing options...
Graskie Posted January 22, 2014 Share Posted January 22, 2014 I would think, if it works on the Elite, it should work using RM. Have you programmed it properly and fully on RM? Sometimes it's worth switching off the Elite and RM, restarting and see what happens. I think you may have problems because you tried to replace one loco with another. No need to do that. Why didn't you just program the non-Hornby loco as an additional one with a different ID? Link to comment Share on other sites More sharing options...
Fishmanoz Posted January 23, 2014 Share Posted January 23, 2014 Given it is running OK, I suspect you may not have allocated the correct sounds to the functions in the function list in the loco setup window. Then having done the allocations, don't forget to write those to the decoder. This is the final step Graskie is alluding to being necessary in his post I think. Link to comment Share on other sites More sharing options...
Fishmanoz Posted January 23, 2014 Share Posted January 23, 2014 All has to be done on the programming track of course. Link to comment Share on other sites More sharing options...
St1ngr4y Posted January 23, 2014 Share Posted January 23, 2014 Graskie said: I think you may have problems because you tried to replace one loco with another. No need to do that. Why didn't you just program the non-Hornby loco as an additional one with a different ID? I thought you could only configure two locos with the Demo version of RM... Ray Link to comment Share on other sites More sharing options...
Graskie Posted January 24, 2014 Share Posted January 24, 2014 Sorry, I didn't realise that was so. I can only wonder if all traces of the loco replaced have been deleted from RM. And I often switch everything off after any change. Have you done that after deletion and before and after adding the new loco details? Link to comment Share on other sites More sharing options...
Bunsen Posted January 25, 2014 Author Share Posted January 25, 2014 sorry for delay in replying yes it is a Loksound decoder. Yes you can only have two locos in the Railmaster Demo . I did delete one completely before adding the non Hornby sound loco. I have done nothing on the programming track though. When I tried the Hornby sound loco I just picked the correct loco from their list and hey presto it all worked .I just assumed it would be similar for the non Hornby one.I just set the speeds on the railmaster and assigned 6 sound functions including sound on/off in the control panel.I have not had the loco on the programming track.Is that what I have done wrong? Link to comment Share on other sites More sharing options...
