Smithy58 Posted March 2, 2014 Share Posted March 2, 2014 I have come back to running my n gauge layout after completing the wiring up to ensure it is completely electrified to run dcc locos. The issue I have is that train 2has become train 3 again which coincides with another train 3 as they both started moving at the same time. So I have tried to reprogram the id nos after removing all the other locos off the track. The rail master software does not seem to be letting me change the id. Can anybody help in giving a step by step process of how to do this as I am not sure if I have followed it right? Any help appreciated. Regards Colin Link to comment Share on other sites More sharing options...
Fishmanoz Posted March 3, 2014 Share Posted March 3, 2014 Hi smithy, it is covered well in the RM manual but a couple of points to remember - can only change ID when connected to the programming output, not the track output. Then after changing the ID, don't forget to actually write it to the decoder as per the final instruction. Link to comment Share on other sites More sharing options...
Smithy58 Posted March 3, 2014 Author Share Posted March 3, 2014 Fishmanoz said: Hi smithy, it is covered well in the RM manual but a couple of points to remember - can only change ID when connected to the programming output, not the track output. Then after changing the ID, don't forget to actually write it to the decoder as per the final instruction. Link to comment Share on other sites More sharing options...
Smithy58 Posted March 3, 2014 Author Share Posted March 3, 2014 Thanks for your help oddly enough I programmed them initially without going into program mode, however I have followed your advice and it worked a treat. Link to comment Share on other sites More sharing options...
Fishmanoz Posted March 3, 2014 Share Posted March 3, 2014 Glad I was able to help and that your problem is solved. But this isn't good enough. We can't close off the thread just like that. We need at least 10 pages of learned discussion on the NMRA spec, CV definitions, long addressing v short addressing in particular, and I don't know what else. Well I know that Graskie will find at least one word play to remind us of the ridiculous, and he may even develop an entire treatise on sightseeing in London on a double decker bus with no roof at all. Or maybe not. Link to comment Share on other sites More sharing options...
