Jbwhitch Posted March 11, 2014 Share Posted March 11, 2014 Hi I have started the conversion of my layout to dcc. I have elink and are successfully running an engine with elink and lap top with iPad. However I want to now take control of the points. I have 8-9 points I can not decide on a select controller or an accessory decoder, what do you think? Thanks John Link to comment Share on other sites More sharing options...
Graskie Posted March 11, 2014 Share Posted March 11, 2014 Welcome to the forum. The Select is just a DCC controller. You already have eLink which can be used to operate points as well. You would, however, need to use accessory decoders for points operation, whatever you do, if you want DCC operation of them. Link to comment Share on other sites More sharing options...
Fishmanoz Posted March 12, 2014 Share Posted March 12, 2014 Just like eLink, the Select can only operate points via an accessory decoder, just as both operate a loco via a loco decoder. Link to comment Share on other sites More sharing options...
Jbwhitch Posted March 12, 2014 Author Share Posted March 12, 2014 Thanks both for help, I got a bit confused I thought that the select directly controlled the points, but it makes sense to still need an accessory decoder with both control systems. Thanks john Link to comment Share on other sites More sharing options...
