Tomp Posted March 25, 2014 Share Posted March 25, 2014 Hi folks My first post and question. RailMaster advises that a Static IP address is used for communicating to the server. I had enough trouble trying to get my com port working and I have no idea how to set a static IP address, I can't see any information on the instruction sheets on how to do this. I have it working and communicating with an ipad and Android Phone using the default IP address on my laptop but the program informs me that the connection may be unstable. Will I be alright or safe using this default IP address? Also the display on the Android Phone is not complete the lower control box is cut off at the bottom and doesn't show the Shunt/Cruise/Stop buttons and I can't scroll it up, any ideas? Thanks Link to comment Share on other sites More sharing options...
Fishmanoz Posted March 25, 2014 Share Posted March 25, 2014 Hi Tom, welcome to the forums. HRMS assert that static IP addresses are essential for stable communication to your handheld. The handheld manual has quite comprehensive instructions on how to go about doing this st both ends, server and handheld, but I agree it is not easy. One thing that is not covered is that the simplest way to do it is to set as static the addresses already assigned by Windows. You can find these by opening a command window and typing the ipconfig command which will tell you all of the assigned addresses. Use the IPv4 address as the static one to set, and the subnet mask address too. So yes, the default is ok but only when you then set it to static. Good luck. You are the second person recently with the Android problem so RM Support needs to be made aware of it. Email them from within the Help window of RM. They are very responsive. Link to comment Share on other sites More sharing options...
Tomp Posted March 25, 2014 Author Share Posted March 25, 2014 Fishmanoz said: Hi Tom, welcome to the forums. HRMS assert that static IP addresses are essential for stable communication to your handheld. The handheld manual has quite comprehensive instructions on how to go about doing this st both ends, server and handheld, but I agree it is not easy. One thing that is not covered is that the simplest way to do it is to set as static the addresses already assigned by Windows. You can find these by opening a command window and typing the ipconfig command which will tell you all of the assigned addresses. Use the IPv4 address as the static one to set, and the subnet mask address too. So yes, the default is ok but only when you then set it to static. Good luck. You are the second person recently with the Android problem so RM Support needs to be made aware of it. Email them from within the Help window of RM. They are very responsive. Link to comment Share on other sites More sharing options...
Tomp Posted March 25, 2014 Author Share Posted March 25, 2014 Thank you very much Fishmanoz For your extremely helpfull reply. I believe I am capable of setting my default IP to static, I believe I can do this by changing the option from "Automatic" in the network settings, I don't feel comfortable doing anything else. Tom Link to comment Share on other sites More sharing options...
Fishmanoz Posted March 26, 2014 Share Posted March 26, 2014 The thing is Tom, once you change from automatic, you then have to enter the addresses you want. Running ipconfig is what tells you what you need to set them to. Link to comment Share on other sites More sharing options...
