andneta Posted April 20, 2014 Share Posted April 20, 2014 Hi all I have a dcc layout using a hornby select controller it has worked fine for 3 days had a train derailrd and now it wont run there is power on the track checked with av meter even tried in analogue mode with a dc train but that wont run pluged power connection into aux side and the train worked but with no speed control any ideas poss faulty select unit Link to comment Share on other sites More sharing options...
Rog RJ Posted April 20, 2014 Share Posted April 20, 2014 andneta said: Hi all I have a dcc layout using a hornby select controller it has worked fine for 3 days had a train derailrd and now it wont run there is power on the track checked with av meter even tried in analogue mode with a dc train but that wont run pluged power connection into aux side and the train worked but with no speed control any ideas poss faulty select unit A loco derailing can cause a short circuit that can reset the decoders in the locos. If they have reset then they will have the address 03, so try running them as 03. If they are OK on address 03 you can re-address them to whatever address you want to use. Link to comment Share on other sites More sharing options...
Fishmanoz Posted April 20, 2014 Share Posted April 20, 2014 Or maybe you need to reset the Select. Link to comment Share on other sites More sharing options...
andneta Posted April 21, 2014 Author Share Posted April 21, 2014 Hi nothing will run not even on 03 have reset the select thanks looks like have to try and contact hornby Link to comment Share on other sites More sharing options...
andneta Posted April 23, 2014 Author Share Posted April 23, 2014 magfan said: does the select boot up ok it goes through a numbers display then goes to 03 0n the lcd , what happens when you try to programme a loco ? the led shoud flash up to 8 times what happens when you short the track ? the lcd should flash Link to comment Share on other sites More sharing options...
andneta Posted April 23, 2014 Author Share Posted April 23, 2014 Thanks for all your help looks like the decoder had reset its self Link to comment Share on other sites More sharing options...
