jacksprat. Posted May 10, 2014 Share Posted May 10, 2014 Has anyone had experience in fitting a decoder to a Wren W2232 0-6-0 diesel loco? Link to comment Share on other sites More sharing options...
Fishmanoz Posted May 10, 2014 Share Posted May 10, 2014 Jack, I don't have any Wrenn experience but, irrespective, the principle of fitting a decoder still applies. That means, start by separating the pickup wiring from the motor connections and you can discard any suppression components. Then you must ensure there is no connection between the motor and the chassis, motor connections must be isolated from everything. Also, I don't know whether Wrenn has pickups each side or whether one side comes from wheels to axles to chassis. But again, connect one side pickups to decoder red and other side/chassis to decoder black. Now motor connections go to decoder orange and grey. That's all there is to it. Test on address 03 before reassembly and programming to your preferred address. Link to comment Share on other sites More sharing options...
81F Posted May 11, 2014 Share Posted May 11, 2014 jacksprat. said: Has anyone had experience in fitting a decoder to a Wren W2232 0-6-0 diesel loco? As an experiment I fitted a cheep unbranded decoder to the Wren LMS 0-6-2T (not sure how closely related it is to the Diesel shunter though. The method I used was the same as would be used for the Triang X04. It works quite well but the control is a bit all or nothing. If the shunter has the vertical motor housed within a solid chassis (like the original Hornby 0-6-2T you could have your work cut out trying to isolate the carbon brush which takes it's power from the chassis. Link to comment Share on other sites More sharing options...
The son of Triangman Posted May 12, 2014 Share Posted May 12, 2014 Yup, isolating the brushes on the old veticle H/D motor requires a fair amount of work alas. Link to comment Share on other sites More sharing options...
jacksprat. Posted May 12, 2014 Author Share Posted May 12, 2014 The son of Triangman said: Yup, isolating the brushes on the old veticle H/D motor requires a fair amount of work alas. I'm not familiar with the Wren LMS 0-6-2T or the Triang loco but the hornby 0-6-2t seems like the one that Ive got, pick ups one side only vertical motor housed in the cab brass worm drive and brass final gear drive I would like to convert it because it is a solid heavy engine ideal for shunting up inclines of which there are two in dc mode it pulls nine coaches up them with out a problem hence why I would like to convert to dcc but I don't want to destroy the motor or decoder in the process so any ideas or guidance would be very welcome Ive only taken the body of and had an in depth look haven't had the bottle to go any further yet Link to comment Share on other sites More sharing options...
The son of Triangman Posted May 12, 2014 Share Posted May 12, 2014 It can be done but is a long job and very time consuming and may require tapping of screw threads as some H/D concersions do. The brushes must be plastic sleeved so they don't short out on the brass brush holders for starters, there should be no direct power contact to the motor control wires or shoers or the decoder will go pop, the rest of the conversion is reasonably straight forward. One advantage you have is that it;s a two rail loco which makes life easier. However it would be easier to just buy the ex-D.pol model made by Hornby (China) which Hornby still make at times and making DCC. Link to comment Share on other sites More sharing options...
Graskie Posted May 12, 2014 Share Posted May 12, 2014 Jack, you can have one of my bottles if you like (empty of course!). Sounds like a big job on your hands. Best of luck with it. Link to comment Share on other sites More sharing options...
jacksprat. Posted May 12, 2014 Author Share Posted May 12, 2014 The son of Triangman said:Thanks for the latest info triangman it does seem to be a very complex job but I am lucky in that my brother is an electronics engineer and I will call on his services to look into the possible conversion. Graskie I will take you up on the offer of a bottle but a full one I can drink it whilst watching the conversion being done I hope I will of course tell everyone who has kindly donated there experience to this matter when and if the conversion is complete. I just feel if I buy one as you suggest it takes all the fun out of it. It can be done but is a long job and very time consuming and may require tapping of screw threads as some H/D concersions do. The brushes must be plastic sleeved so they don't short out on the brass brush holders for starters, there should be no direct power contact to the motor control wires or shoers or the decoder will go pop, the rest of the conversion is reasonably straight forward. One advantage you have is that it;s a two rail loco which makes life easier. However it would be easier to just buy the ex-D.pol model made by Hornby (China) which Hornby still make at times and making DCC. Link to comment Share on other sites More sharing options...
Fishmanoz Posted May 12, 2014 Share Posted May 12, 2014 Jack, just on posting, if you put your content somewhere outside those 2 replies in square brackets, it won't come out looking like yours above but instead like yours higher up at 15.50. Or just hit Post Reply instead of Reply to someone's post. Link to comment Share on other sites More sharing options...
jacksprat. Posted May 13, 2014 Author Share Posted May 13, 2014 Think I might have got it right now Fishmanoz thanks for pointing me in the right direction. Link to comment Share on other sites More sharing options...
Fishmanoz Posted May 13, 2014 Share Posted May 13, 2014 No worries Jack. Link to comment Share on other sites More sharing options...
Fishmanoz Posted May 13, 2014 Share Posted May 13, 2014 Some people get even more clever, they put in extra square bracket replies so they can have a little bit of someone' spots, then their comment, then more of the post, more of theirs etc. Can be useful at times but often repeating what someone said just takes up real estate pages here without adding much. We have some really long multi-page threads as a result. Then again, others like to make sure we know what they are replying to, everyone is different. Link to comment Share on other sites More sharing options...
Fishmanoz Posted May 13, 2014 Share Posted May 13, 2014 Oops, that's someone's post, not spots. Correcting my typos is my favourite way of using up the real estate. Link to comment Share on other sites More sharing options...
