stewart166 Posted July 10, 2014 Share Posted July 10, 2014 hello everyone i have got the lenze ls 150 but i have no clue on how to set it up and the instructions are no help can someone help me please with setting it up thanks Link to comment Share on other sites More sharing options...
Fishmanoz Posted July 10, 2014 Share Posted July 10, 2014 Don't have access to my RM just now. Is the Lenz in the RM drop down list? If so, ask RM Support by email from within the Help window of RM. Otherwise, let us know the link to the manual ans someone may be able to help. Then also let us know more specifically what you don't understand in it. Link to comment Share on other sites More sharing options...
stewart166 Posted July 11, 2014 Author Share Posted July 11, 2014 it is on the drop down list and well here is the link to the manual http://www.lenzusa.com/1newsite1/Manuals/LS150.pdf now what i dont get is that it says Connection to track output of the digital system what does that mean and where do i plug the decoder for me to be anle to use it on RM Link to comment Share on other sites More sharing options...
Fishmanoz Posted July 11, 2014 Share Posted July 11, 2014 All accessory decoders must have their input connected to the track output of a DCC controller to operate. This must be done either directly, or indirectly by connection to the track itself or a DCC bus. The outputs or ports of the decoders are then connected to your point motors. Before you can operate them, your decoder must have its addresses programmed for each port. This will be done one of two ways. The first is that the decoder is connected to the programming output of your controller and the desired address or group address selected. See the Rm am manual for details, or also your Lenz manual. The second way is by moving a small switch on the decoder from Run to Learn, then just throwing the desired point from your RM schematic, then switching back to Run and it's done. With this method, the decoder is connected to the Track output, not the programming output. The decoder manual will tell you which of the two ways is used for your decoder. I will check out your manual next and tell you which way works for the Lenz. Link to comment Share on other sites More sharing options...
Fishmanoz Posted July 11, 2014 Share Posted July 11, 2014 The manual is quite clear on how it is done. It uses the Learn/Run method but goes into Learn mode by holding down the push button for 3 seconds. See page 12 of your manual. And your decoder also needs to be connected to a separate AC supply at all times. Again, your manual is clear. Link to comment Share on other sites More sharing options...
