Cookie cook Posted August 2, 2014 Share Posted August 2, 2014 Hello I have got the elink and can run trains fine but I cannot change the cv values, I have tried connecting it to a seperate piece of track which I converted to digital as well as on my main track and I have the same problem with both, Link to comment Share on other sites More sharing options...
Cookie cook Posted August 2, 2014 Author Share Posted August 2, 2014 its annoying because I want to run my locos independently but as I can't change the default Id address from 3 I can't would really love some help with this Link to comment Share on other sites More sharing options...
Fishmanoz Posted August 2, 2014 Share Posted August 2, 2014 Hi Adam, welcome to the forums and let's start with basics. I'm going to assume you've installed as administrator, RM is not being blocked by your virus software, your com port as in RM Setup is the same as in Device Manager, and it has updated to the latest v1.55. Is that all ok so far?Next, have you connected to the programming output, not the track output? Then can you read CVs including ID? And getting real values incl ID 003, not 255 which means it is not reading. If that works, now follow the instructions to change the ID, including the final instruction to write it to the decoder. There is a button for that at the bottom of the loco setup screen and the instructions aren't very clear on this last step. Link to comment Share on other sites More sharing options...
Fishmanoz Posted August 2, 2014 Share Posted August 2, 2014 Kiwi is quite right. See first sentence of my second para. Link to comment Share on other sites More sharing options...
Michael_A Posted August 13, 2014 Share Posted August 13, 2014 Unfortunately even I sometimes have to ask: 'Have you read the manual'I know its a large document, and us guys normally don't need any instructions, but this system is compelx and actually the Hornby manuals are well written and very easy to follow. Link to comment Share on other sites More sharing options...
