RDD Posted September 6, 2014 Share Posted September 6, 2014 When running my DCC Hornby class 40 at high speeds it seams to run ok but as soon as I slow it down it stops and starts all round the track.Can anyone help.Regards Link to comment Share on other sites More sharing options...
Fishmanoz Posted September 6, 2014 Share Posted September 6, 2014 Is it new? If so, have you run it in at medium speed for half an hour in each direction? If not, see how it goes after that. Is it Hornby DCC fitted and if not, what sort of decoder are you using? Link to comment Share on other sites More sharing options...
RDD Posted September 7, 2014 Author Share Posted September 7, 2014 It's about a year old and was DCC ready. I can't remember what decoder i fitted but it was not a Hornby one.Do you think a Hornby decoder will be better, i do have a spare one. Link to comment Share on other sites More sharing options...
morairamike Posted September 8, 2014 Share Posted September 8, 2014 You are running DCC and yes the wheels have to be clean etc etc, but how is the power fed to your track? One place and then relying on the fishplates at the track joints OR do you have a power bus and droppers to each piece of track? If fishplates then they stretch over time and loose their good contact with the rail and give intermittent running. When your loco stalls try pressing down on the rail joint neraest to it, if it starts again then it a fishplate problem. Link to comment Share on other sites More sharing options...
