bms Posted September 6, 2014 Share Posted September 6, 2014 I want to allow a group of points and signals controlled by DCC Concepts Cobalt levers to basically operate 2 pairs of point motors and signals (no interlocking) (no problem) and to feed the point and signal positional information into the elink track diagram (problem). There are plentiful contacts on the point/signal levers but I can't see where to go from there!At present the only way I can see is verbal transfer between the signal bax and the elink operator; the elink operator then changing the points/signals on his diagram to match the signal box - can this part be automatedIf successful this will give an assistant a job to do in an operating session!Any ideas?RegardsBasil Link to comment Share on other sites More sharing options...
