dwragg Posted November 23, 2014 Share Posted November 23, 2014 I have just taken delivery on the new Gadwell A4 Class with DCC and TTS sound. Never experienced this type of sound before so that makes me a novice! Problem is I have no sound!! I've tried all I can think of (I'm not that novice!) but nothing there. I have the Select controller and am aware it has restrictions. Can someone guide me through what I should be doing, or do I have a faulty engine....or controller? Link to comment Share on other sites More sharing options...
gilbo2 Posted November 23, 2014 Share Posted November 23, 2014 Enabling F1 is the key to switching on most of the other function sounds. Have you switched that on first, hearing the idle steam sound? Link to comment Share on other sites More sharing options...
96RAF Posted November 23, 2014 Share Posted November 23, 2014 The other thing is are you talking to the loco on its actual address. e.g. 003 as it comes out of the box or whatever address you may have given it and can you get the motor to respond to commands. If so and F1 hasn't sorted your problem try to reset the decoder sounds only, by writing value 5 to CV8. Link to comment Share on other sites More sharing options...
dwragg Posted November 23, 2014 Author Share Posted November 23, 2014 The other thing is are you talking to the loco on its actual address. e.g. 003 as it comes out of the box or whatever address you may have given it and can you get the motor to respond to commands. If so and F1 hasn't sorted your problem try to reset the decoder sounds only, by writing value 5 to CV8. Yes, the engine is now on command 002 set by me. Engine responds correctly to its commands motion wise. With 002 still on Pressing function +1 does nothing. I must admit I'm lost when you say 'try to reset the decoder sounds only by writing value 5 to CV8?! Link to comment Share on other sites More sharing options...
Fishmanoz Posted November 23, 2014 Share Posted November 23, 2014 RAF was forgetting you are using Select which cannot write to CV8 or any other CV except those accessed by its menu system such as loco ID, accel, decel etc. there have been other things suggested for TTS locos, like speed step adjustment, but none of these csn be done with a Select. if if you've already tried all the things covered in the leaflet that comes with it, can I suggest you ring Customer Care to see if they can help? Link to comment Share on other sites More sharing options...
Yelrow Posted November 23, 2014 Share Posted November 23, 2014 Dwragg, hi, when you have time, look at Elink/railmaster package, for the future. computer controlled, less than the price of your loco, and it will give you a lot more flexibilty in the future, to adjust cvs, etc. You can download a trial free, and see what you think. john Link to comment Share on other sites More sharing options...
dwragg Posted November 23, 2014 Author Share Posted November 23, 2014 RAF was forgetting you are using Select which cannot write to CV8 or any other CV except those accessed by its menu system such as loco ID, accel, decel etc. there have been other things suggested for TTS locos, like speed step adjustment, but none of these csn be done with a Select. if if you've already tried all the things covered in the leaflet that comes with it, can I suggest you ring Customer Care to see if they can help? Thanks all for the replys. Still no sound after trying everthing again. Now I'm thinking it's the Select controller as I have another DCC engine with front light, always had this switched on, tried to switch off but it will not, so thinking it may be the Select at fault. I will call customer care in the morning to see what they have to say. Link to comment Share on other sites More sharing options...
Fishmanoz Posted November 24, 2014 Share Posted November 24, 2014 Good clue on the lights dw. Link to comment Share on other sites More sharing options...
pidder Posted November 24, 2014 Share Posted November 24, 2014 The Select does have a "factory reset" option, page 19 of the handbook. This MIGHT solve the problem? Link to comment Share on other sites More sharing options...
pidder Posted November 24, 2014 Share Posted November 24, 2014 Also, have you tried pressing function alone, then 1, rather than both together? Link to comment Share on other sites More sharing options...
dwragg Posted November 24, 2014 Author Share Posted November 24, 2014 The Select does have a "factory reset" option, page 19 of the handbook. This MIGHT solve the problem? Ok. not tried that, but will tonight, thanks. Link to comment Share on other sites More sharing options...
dwragg Posted November 24, 2014 Author Share Posted November 24, 2014 Also, have you tried pressing function alone, then 1, rather than both together? Tried every permutation, only one I've not tried is throwing it all out the window!!......have come close though!! but thanks for your time. Link to comment Share on other sites More sharing options...
ff2nd Posted November 26, 2014 Share Posted November 26, 2014 Also, have you tried pressing function alone, then 1, rather than both together? Tried every permutation, only one I've not tried is throwing it all out the window!!......have come close though!! but thanks for your time. Just a thought. When you start the Select up, what numbers does it display? If the first number is 10, 11 or 12, I would suggest sending the controller back to Hornby to have the Firmware updated. Versions 13 and 14 "talk" to sound locos a lot better for some reason! Link to comment Share on other sites More sharing options...
F3BLC Posted November 26, 2014 Share Posted November 26, 2014 RAF was forgetting you are using Select which cannot write to CV8 or any other CV except those accessed by its menu system such as loco ID, accel, decel etc. there have been other things suggested for TTS locos, like speed step adjustment, but none of these csn be done with a Select. if if you've already tried all the things covered in the leaflet that comes with it, can I suggest you ring Customer Care to see if they can help? Thanks all for the replys. Still no sound after trying everthing again. Now I'm thinking it's the Select controller as I have another DCC engine with front light, always had this switched on, tried to switch off but it will not, so thinking it may be the Select at fault. I will call customer care in the morning to see what they have to say. Link to comment Share on other sites More sharing options...
F3BLC Posted November 26, 2014 Share Posted November 26, 2014 I have just taken delivery on the new Gadwell A4 Class with DCC and TTS sound. Never experienced this type of sound before so that makes me a novice! Problem is I have no sound!! I've tried all I can think of (I'm not that novice!) but nothing there. I have the Select controller and am aware it has restrictions. Can someone guide me through what I should be doing, or do I have a faulty engine....or controller? Link to comment Share on other sites More sharing options...
idlemarvel Posted November 27, 2014 Share Posted November 27, 2014 Also, have you tried pressing function alone, then 1, rather than both together? Tried every permutation, only one I've not tried is throwing it all out the window!!......have come close though!! but thanks for your time. Just a thought. When you start the Select up, what numbers does it display? If the first number is 10, 11 or 12, I would suggest sending the controller back to Hornby to have the Firmware updated. Versions 13 and 14 "talk" to sound locos a lot better for some reason! This is the first time I have seen reference to v13 or v14 for the Select, I thought the latest and last version was 12 a.k.a 1.2? Can Hornby please tell us what the latest version is? I have searched the web site and I can only find reference to 1.2. Also if there is a version 14 (1.4) can any Select be upgraded? Thanks Link to comment Share on other sites More sharing options...
Yelrow Posted November 27, 2014 Share Posted November 27, 2014 IdleMarvel, i can tell you the answer. My select is recently back from Hornby. When you power it up, it goes 14-30-03. That is the latest version. john. I belice any select can be upgraded, mine was very old. john Link to comment Share on other sites More sharing options...
Yelrow Posted November 27, 2014 Share Posted November 27, 2014 Further to that, when it was returned there was something about previous problems, now resolved. john Link to comment Share on other sites More sharing options...
andrew_alliston Posted April 28, 2015 Share Posted April 28, 2015 Did you end up with a satisfactory answer to your problem?I have just received my Gadwell this month and I'm having the same problem through Railmaster Pro. No sound, otherwise it runs perfectly!! Link to comment Share on other sites More sharing options...
2e0dtoeric Posted April 28, 2015 Share Posted April 28, 2015 Come on, guys - when you reply to a previous comment - do NOT use the blue 'reply' button.Scroll down to the white box below, and type your comment n there, then press the GREEN 'reply' button.This prevents endless repetition of all the previous comments - and makes your words stand out, instead of being hidden in the other stuff. Link to comment Share on other sites More sharing options...
ozcavebear Posted April 28, 2015 Share Posted April 28, 2015 Couple of things that may be of use. Have a TTS DoG and have tested that on a Select without the latest firmware and it works fine with TTS sound so a fair assumption to say that a TTS Gadwell should also work fine on a Select.Secondly and maybe a longshot, but worth checking, I recently purchased a brand new Hornby Class 08 R2977XS loco sound fitted and it had the same problem, would operate perfectly forward and reverse but no sound. Turned out to be one of the wires had come off the speaker, perhaps in transit. Soldered back on on and all ok. I know its a different loco but easy to do and worth checking. Link to comment Share on other sites More sharing options...
