keven_4ever Posted November 27, 2014 Share Posted November 27, 2014 Hi all, I bought a couple of R8014 point motors and R8247 accessory decoders, and plan to use elink and RM to control them, but after two days strugglling, still can't get it working. Please give me some advice. Here is what i did: connect R8014 to one of R8247 port: red wire to +, black wire to C and green to -. Then connect R8247 to track. Then track is connecting to PROG mode of elink. Finally, when open RM, i can see R8247 has been recoganized, it shows ID 12,1 and 4 ports. But when i click the red circle (test button), the point motor doesn't switch!!! And since it is solenoid motor, i can't use meter to verify what's wrong. Please give me some advice, thank you very much! BR/Keven Link to comment Share on other sites More sharing options...
soloscotty Posted November 28, 2014 Share Posted November 28, 2014 the wire need to be red wire to - black wure to c for the power and green wire to + work for me need this to work Accessory Decoder - R8247 Link to comment Share on other sites More sharing options...
keven_4ever Posted November 28, 2014 Author Share Posted November 28, 2014 Hi all, I bought a couple of R8014 point motors and R8247 accessory decoders, and plan to use elink and RM to control them, but after two days strugglling, still can't get it working. Please give me some advice. Here is what i did: connect R8014 to one of R8247 port: red wire to +, black wire to C and green to -. Then connect R8247 to track. Then track is connecting to PROG mode of elink. Finally, when open RM, i can see R8247 has been recoganized, it shows ID 12,1 and 4 ports. But when i click the red circle (test button), the point motor doesn't switch!!! And since it is solenoid motor, i can't use meter to verify what's wrong. Please give me some advice, thank you very much! BR/Keven Ok, after call Hornby support, i finally get it working. The trick is that you have to develop a panel with the point in Track mode (not PROG mode). The test port button in PROG mode doesn't work. Now i have another challenge: it doesn't work again when i use Sprog III which is my final goal as with sprog i can control layout with my own software. Any one has experience before? BR/Keven Link to comment Share on other sites More sharing options...
