late starter Posted December 7, 2014 Posted December 7, 2014 Hello, all,Ive successfully laid & tested my initial Gloucester set, all ok. Im in the process of adding another inner oval, plus using the full 7 ft by 4 ft board, hoping to create a station & sidings for engine sheds.The problem is every dealer ive visited is short of points, is this a typical problem at this time of year? Also, ive finally made the outfit a permanent site, so i dont really see the need for using track pins.Earlier, some members were saying it would be good if Hornby returned to the uk, i wish they would! What was the problem with moving moulds to the uk? is the situation in China difficult if you wish to set up elsewhere, i would be interested to know? KC.
The Doc Posted December 7, 2014 Posted December 7, 2014 Hi late starter, and welcome to this great hobby. If you cannot find the points you want at your local shops, there should be plenty available online. Try ebay for example. Also, if it's the standard left/right hand points you need, Peco make virtually identical points - if anything they are slightly better.
rustonhornsby Posted December 7, 2014 Posted December 7, 2014 hi,late starter,try the hornby on line shop on this site.
rustonhornsby Posted December 7, 2014 Posted December 7, 2014 hi,me again,just checked the hornby on line shop and left hand and right hand points are in stock .
