ss002d6252 Posted January 2, 2015 Share Posted January 2, 2015 Rather than using a R8201 Track Link wire to link the power for the inner and outer rings of the analogue track circuit is it possible to the achive the same effect by joining the tracks with insulated copper cabling ?I'm fitting the track and mat to a base board so it would be easier to route some wires underneath if it's a workable alterative.ThanksCraig Link to comment Share on other sites More sharing options...
Fishmanoz Posted January 2, 2015 Share Posted January 2, 2015 Welcome to the forums Craig and yes you can. Just make sure your connections go track A to track A on each loop and track B to track B. If you don't do this, you'll get a short when you switch your crossover points to go from one loop to the other. Link to comment Share on other sites More sharing options...
ss002d6252 Posted January 2, 2015 Author Share Posted January 2, 2015 Welcome to the forums Craig and yes you can. Just make sure your connections go track A to track A on each loop and track B to track B. If you don't do this, you'll get a short when you switch your crossover points to go from one loop to the other. Thank you - it'll sort my problem and save a couple of quid at the same time. Craig Link to comment Share on other sites More sharing options...
Graskie Posted January 3, 2015 Share Posted January 3, 2015 Do you reckon poliss could be used as a copper cable? Link to comment Share on other sites More sharing options...
Fishmanoz Posted January 3, 2015 Share Posted January 3, 2015 Yes, but you'll first have to gauge how much current he can handle. Link to comment Share on other sites More sharing options...
Graskie Posted January 3, 2015 Share Posted January 3, 2015 Wire you saying that, Fishy? Link to comment Share on other sites More sharing options...
