R1173 Not Moving
Olivert12
Posted
Hi
I have just started using the set Western Master. I have got the elink woorking after many attemps but now the  loco has stopped moving, the day after applying oil on the wheels to run it smoother.
Any suggestions for servicing/repair?
Olivert12
Posted
Hi
Olivert12
Hello,
Welcome to the Forum.
If you applied too much oil, it might be preventing the electric current passing from the track into the wheels. Make sure you remove surplus oil from the wheels and clean the tracks in case any oil has got onto them.
Ray
Posted
Hi
Olivert12
Hello,
Ray
How do I do that, and what tools are required
Olivert12
Posted
Clean cloth/cotton buds and if necessary IPA (iso-propyl-alcohol) cleaner, obtainable from your local chemist.
Posted
Thanks, should I dissamble the loco in any way, if so, how?
Many thanks
Posted
You probably won't be able to get IPA from your local chemist (if you are in the UK) but you can use methylated spirits instead, which you should be able to get from a hardware store such as Wilkos or any DIY store.  Methylated spirits isn't quite so good as IPA as it's not so pure but works well.
Posted
Shouldn't be necessary to take it apart. Just clean what you can see, in particular around the wiper contacts that rub against the wheel backs.
You can use a small square 9V battery to move the wheels around a bit, by pressing the battery contacts against the wheels for a moment.
Posted
Have cleaned it as much as I could and tested it with the 9v battery, and the wheels moved erratically for a few seconds the stopped. Any ideas where the pickups on R1173 or any dcc loco are?
Thanks
Olivert12
