Dwarfboysim Posted January 5, 2015 Share Posted January 5, 2015 Hi,What are the recommended system requirements for a desktop PC or laptop for Rail Master? Thanks,Greg Link to comment Share on other sites More sharing options...
St1ngr4y Posted January 5, 2015 Share Posted January 5, 2015 Hello Greg,This has been posted by Hornby Railmaster Support in the past:-"RailMaster will work on computers running Windows XP with as little as 64Mb RAM on a Pentium 233MHz processor and around 100Mb of free hard disk space and at least one USB port.Since this requirement is very low by today's standards, essentially, any new computer will be more than adequate. RailMaster runs on any Windows operating system from XP onwards, including NT, Vista, 7, 8 and 8.1 in either 32 or 64-bit configurations.When running RailMaster it is highly advisable not to run other programs at the same time and you should not use a USB hub to connect your DCC controller. RailMaster has been optimised for touch screen computers, although will work with a mouse. The larger the screen resolution you can afford the more of your track plan and loco controllers you will be able to see." Hope this helps.Ray Link to comment Share on other sites More sharing options...
