Bigwink Posted January 11, 2015 Share Posted January 11, 2015 The light on my Elink keeps flashing, and there appears to be no communication with any locomotive on either the prog or track conections. I have tried different cables, usb ports and even completely uninstalling and reinstalling Railmaster and related drivers to no avail. Help! Link to comment Share on other sites More sharing options...
Fishmanoz Posted January 11, 2015 Share Posted January 11, 2015 Hi Bw, welcome to the forums. Was it running previously? Tell us more. Link to comment Share on other sites More sharing options...
Augustus Caesar Posted January 11, 2015 Share Posted January 11, 2015 The light on my Elink keeps flashing, and there appears to be no communication with any locomotive on either the prog or track conections. I have tried different cables, usb ports and even completely uninstalling and reinstalling Railmaster and related drivers to no avail. Help!Welcome to the forum... When attempting to use different ports you should use the lowest numered port you can, either 4 or under. Different USB cables are extremely unlikely to offer up any difference... they rarely go wrong or are the wrong type. If the laptop or PC is new and has USB 3 ports try using USB 2 instead as some USB ports on new machines will ONLY run USB 3 equipment, contrary to what either the shop, brochure or experts say! Trust me... From the limited info in your post I would tempted to test the power supply if you can to see if enough juice is getting to the unit (eLink). If you have, or know someone who has, a multimetre then simply plug in the supply to the wall outlet and test using the correct settings. Even a trip to Maplins and a kind ask may just offer up a free test for you. Link to comment Share on other sites More sharing options...
Fishmanoz Posted January 11, 2015 Share Posted January 11, 2015 The reason I asked if it had worked previously was to eliminate incorrect setup as we know this is the problem for most new users on here. If the setup is ok AC, then electrical failure somewhere is a distinct possibility. Link to comment Share on other sites More sharing options...
Bigwink Posted January 12, 2015 Author Share Posted January 12, 2015 Hi Bw, welcome to the forums. Was it running previously? Tell us more.It was running previously, yes Link to comment Share on other sites More sharing options...
Fishmanoz Posted January 12, 2015 Share Posted January 12, 2015 Bw, as AC says, you may have a fault developed. I suggest at this stage, the best thing might be to contact RM Support by email from within the Help window of RM. That method sends them your log file so they can see what is going on. Usually they ask a few questions to ensure you have your setup right in the first place. You can checkout the sort of thing by going to page 2 of this forum and see what I asked a newcomer in the thread called Majestic with eLink. If you tell them the answers to those first up, it could save a little time. Link to comment Share on other sites More sharing options...
Augustus Caesar Posted January 13, 2015 Share Posted January 13, 2015 No probs Fishy mate... I just thought as with other posts with limited info it might be prudent to add a little extra. Your thought on contacting support may be best here though as it does seem like a developed fault unfortunately... but hey... we've been wrong before! lol Link to comment Share on other sites More sharing options...
