acton_north Posted January 15, 2015 Share Posted January 15, 2015 Hi Guys, Sorry if this has been discussed, Ive done a search but couldn't find exactly what my problem solution is. Basically, I have an e-link with railmaster powering my layout. After much frustration, Ive got the basics to work, but, now having issue with changing loco's ID address. I am using hornby 8 pin DCC decoder as Im only really bothered about lights and movement.On putting in the DCC decoder, the locos work on ID 3 (the factory setting) with no issues. I put the loco on the programming track, follow the instructions to change the ID, complete the process and put the loco back on the main track under its new ID. However, nothing happens. Nil. Nada. Zilch. I put it back on the programming track, try chane the CV's just incase, and still nothing. I programme the ID back to address 3, and hey presto, the loco works fine again. However, given I cannot run all my loco's on ID 3, how do I go about changing the ID? Many thanks in advance. Link to comment Share on other sites More sharing options...
St1ngr4y Posted January 15, 2015 Share Posted January 15, 2015 It sounds like your attempt to give the loco its new address hasn't worked properly. Try using Railmaster to read CV's 1 to 8 to see if your programming track is working, then try giving it its new address. Then try to read CV's 1 to 8 again.Ray Link to comment Share on other sites More sharing options...
RDS Posted January 15, 2015 Share Posted January 15, 2015 I agree with Ray. It may be that you are not changing the id at all, either from 03 or back to 03, in which case it has been on 03 all the time.Does the Loco still work on id 03 when you think you have changed it to something else. Link to comment Share on other sites More sharing options...
acton_north Posted January 15, 2015 Author Share Posted January 15, 2015 No the loco doesn't work on 3 when I think Ive changed it, its completly unresponsive. I will try the CV 1-8 idea tomorrow, hopefully that works.Thanks for the suggestions so far. Link to comment Share on other sites More sharing options...
ColinE Posted January 15, 2015 Share Posted January 15, 2015 No the loco doesn't work on 3 when I think Ive changed it, its completly unresponsive. I will try the CV 1-8 idea tomorrow, hopefully that works.Thanks for the suggestions so far.You have probably already done this, if you have sorry but have you also changed the locos ID in the loco listing on railmaster as well the loco? Link to comment Share on other sites More sharing options...
Fishmanoz Posted January 15, 2015 Share Posted January 15, 2015 Given you are using RM to change the ID, I don't think you can do one without the other Colin? Having made a change to the ID, have you read back CV1 as suggested by Ray to see what it says? I am assuming you are trying to change it to a short ID (under 100). Link to comment Share on other sites More sharing options...
96RAF Posted January 16, 2015 Share Posted January 16, 2015 One of my Elites has no PROG output so I get round it by doing CV changes in Operate Mode on the main, including CV1 which the manual says you can't change.I select the loco address that works with the loco I want to readdress, then I ask to change CV1 to the new address and it works.Maybe the eLink will do the same. Link to comment Share on other sites More sharing options...
acton_north Posted January 20, 2015 Author Share Posted January 20, 2015 Hi GuysIve tried again, reading CV's 1-8 only, but, still no luck.Ive tried again and again, but, no matter what I try, when reading the CV's it does not change 'loco address value' from 3 to the number I am attempting to change it to.Im running out of ideas, and patience at the same time as Ive had no end of issues with this software and its really getting on my wick now. Link to comment Share on other sites More sharing options...
St1ngr4y Posted January 20, 2015 Share Posted January 20, 2015 Hi,Have you tried this...Read in CV1Highlight it with your mouse and hit the delete key.Type in the new address you want to give it.Then hit the "Write CV" button at the bottom left of the window.Then try reading CV1 again.Ray Link to comment Share on other sites More sharing options...
Yelrow Posted January 20, 2015 Share Posted January 20, 2015 RAY, thats what i do, allways have, find it simpler. john Link to comment Share on other sites More sharing options...
96RAF Posted January 20, 2015 Share Posted January 20, 2015 You can use the same write to CV1 method to change a loco address on the main in programming 'Operate mode'.You have to confirm the loco address you want to change before making the alts, else you would amend the wrong loco by mistake, so it is fairly foolproof.I found this out by fiddling as my 'spare' Elite will not programme from the PROG terminals. Edit: - just thought of this. Normally you can't read CV values in Operate mode but if your decoder supports Railcom (e.g. Sapphire) and its enabled then you can read back some CV values. Link to comment Share on other sites More sharing options...
Fishmanoz Posted January 20, 2015 Share Posted January 20, 2015 RAF, this will only work with your Elite anyway so not of use to a_n who has RM/eLink which can't do this. a_n, are you getting this with all of your decoders or just one? Given you can read and not write it would seem, I'm wondering if it is a faulty decoder or a faulty eLink. Link to comment Share on other sites More sharing options...
Graskie Posted January 21, 2015 Share Posted January 21, 2015 I had problems recently changing the ID on a sound decoder. I used the standard Hornby Elite procedure which worked on the ID change but interfered with certain other ones. I wasn't sure whose sound decoder it was but eventually identified a particular source which needed CV32 changed to 1 and, after editing, then needed to be reset to 0. It worked perfectly. Link to comment Share on other sites More sharing options...
Graskie Posted January 23, 2015 Share Posted January 23, 2015 Sorry, but what if the same sort of procedure is also required even on an eLink setup, kiwi? The fact that I was referring to my Elite hardly changes that possibility, in which case I am not necessarily going off thread. Link to comment Share on other sites More sharing options...
96RAF Posted January 23, 2015 Share Posted January 23, 2015 Having read your decoder CVs in RM you may find some of the values listed difficult to understand.For anyone wanting to use a long address (Cvs 17 & 18 as opposed to CV1) here is a link to a calculator that gives you the values for CV17 & 18.Its just below the handy CV29 calculator here http://www.2mm.org.uk/articles/cv29%20calculator.htm Link to comment Share on other sites More sharing options...
Fishmanoz Posted January 23, 2015 Share Posted January 23, 2015 Wouldn't it be simpler to just use the Change Loco ID button rather than fiddling with CVs? Clearly having done this and saved it to the decoder, the calculator will tell you what CVs 17 and 18 should be if you read them back. Link to comment Share on other sites More sharing options...
96RAF Posted January 23, 2015 Share Posted January 23, 2015 The problem I found was the change loco id button just made a new loco rather than re-id the existing one. Link to comment Share on other sites More sharing options...
