Gazah Posted January 18, 2015 Share Posted January 18, 2015 Hi GentsNeed some help please!I have wired two point motors to form a crossover, all working well except on the railmaster layout plan for my layout, they show the opposite way, so when line is going straight it show forking off right, and vica versa, any suugestions what I have done wrong or how to fix it?All help greatfull appreciated G Link to comment Share on other sites More sharing options...
Graskie Posted January 18, 2015 Share Posted January 18, 2015 Swap your wires around from power source (track, say) to point motors, or from accessory decoder to the point motor if powered direct from that? Link to comment Share on other sites More sharing options...
Gazah Posted January 18, 2015 Author Share Posted January 18, 2015 Swap your wires around from power source (track, say) to point motors, or from accessory decoder to the point motor if powered direct from that?Hi Graskie,So if I am using the Hornby decoder, and in port 3 Red is + Wire and green is - wire you suggest just swapping these over, will it not damage the deocder? Link to comment Share on other sites More sharing options...
Graskie Posted January 18, 2015 Share Posted January 18, 2015 I don't see why it should, on the face of it, but someone else needs to confirm or deny that. I haven't actually set up any accessory decoders yet, but my suggestion seems pretty reasonable. It should just reverse power to your point motors, and hopefully then fit in with RM showing the correct setup. Link to comment Share on other sites More sharing options...
Graskie Posted January 18, 2015 Share Posted January 18, 2015 Incidentally, Gazah, are you powering each point motor separately or from just one feed leading from one point motor to the other? If the latter, then you would, of course, need to switch over the two wires between the point motor terminals as well, so that they both have the same polarity. Link to comment Share on other sites More sharing options...
Graskie Posted January 18, 2015 Share Posted January 18, 2015 Thinking about it, you don't need to switch the wires from your decoder. As an alternative it could perhaps work if you just switch your point terminals, still ensuring the same polarity for both as described before. Link to comment Share on other sites More sharing options...
Fishmanoz Posted January 18, 2015 Share Posted January 18, 2015 Take a look at the lengthy discussion on this in the thread "Points indicator in passing loop" towards the bottom of RM forum page 1. And to clarify, swapping the positive and negative wires from decoder to point won't damage snything. In fact, even getting it wrong completely and putting common to positive or negative won't do any damage, it just won't work. Link to comment Share on other sites More sharing options...
Graskie Posted January 18, 2015 Share Posted January 18, 2015 Thanks for throwing your (new) hat into the ring on this one, Fishy, confirming what I thought. Link to comment Share on other sites More sharing options...
Fishmanoz Posted January 18, 2015 Share Posted January 18, 2015 I thought I am throwing your hats now? I put up the outlandish unsupportable comment and you put up the hat? Link to comment Share on other sites More sharing options...
Gazah Posted January 19, 2015 Author Share Posted January 19, 2015 I thought I am throwing your hats now? I put up the outlandish unsupportable comment and you put up the hat?Thanks for all the help gents seems now to be working as I had hoped!! Link to comment Share on other sites More sharing options...
Graskie Posted January 19, 2015 Share Posted January 19, 2015 Hats off to me and Fishy then! Glad you sorted it, Gazah. Link to comment Share on other sites More sharing options...
