GWR Greg Posted January 30, 2015 Share Posted January 30, 2015 I am trying to add a message all is okay in set up until I over write " message here" with the text I want. As soon as I save the programme it reverts to "message here". Any ideas? Link to comment Share on other sites More sharing options...
St1ngr4y Posted January 30, 2015 Share Posted January 30, 2015 Hi Greg,This is an outstanding bug which I reported to HRMS a while back. You can't change the time of Display either.I've had similar problems with chain commands. If I want to change the name of the program to be chained, it opens the File Open Dialog window to let you choose the file, but then puts the name of the chosen file into the Notes column of the program editor. But if you then redo the change, 2nd time through it works ok, and continues to work if you have other chain commands to amend in the same program.Ray Link to comment Share on other sites More sharing options...
GWR Greg Posted January 30, 2015 Author Share Posted January 30, 2015 Thanks for the info. Link to comment Share on other sites More sharing options...
RDS Posted January 30, 2015 Share Posted January 30, 2015 ... let you choose the file, but then puts the name of the chosen file into the Notes column of the program editor ...I have had that as well. I haven't reported it though but it was quite frustrating. I just assumed I was doing something wrong but I could never think what that may have been but it is certainly the type of thing I would like to see fixed, sooner rather than later. Link to comment Share on other sites More sharing options...
St1ngr4y Posted January 30, 2015 Share Posted January 30, 2015 ... let you choose the file, but then puts the name of the chosen file into the Notes column of the program editor ...I have had that as well. I haven't reported it though but it was quite frustrating. I just assumed I was doing something wrong but I could never think what that may have been but it is certainly the type of thing I would like to see fixed, sooner rather than later.Tomorrow I'll check that it is still happening and if so, I'll report it through the systemRay Link to comment Share on other sites More sharing options...
HornbyRailMasterSupport Posted January 31, 2015 Share Posted January 31, 2015 We believe this was resolved in the latest revision (1). Try downloading and installing from www.powerpos.com/rail-master/rm_setup.exe and see if this resolves the issue. This revision also fixes the problem with operating functions 21 to 25 on the new TTS sound diesel locos and correctly shows all latching (on/off) functions. Link to comment Share on other sites More sharing options...
RDS Posted January 31, 2015 Share Posted January 31, 2015 I have v1.60, Revision 0 loaded and I have just tried the Chain Command and it worked correctly.(Is there now a Revision 1?) Link to comment Share on other sites More sharing options...
GWR Greg Posted January 31, 2015 Author Share Posted January 31, 2015 I have updated to revision 1. Still cannot change "Message here" Link to comment Share on other sites More sharing options...
HornbyRailMasterSupport Posted January 31, 2015 Share Posted January 31, 2015 If you send us a Help Request we will automatically receive the last program you were working on and see what may be happening on your PC. Please ensure you provide full details in the message. Link to comment Share on other sites More sharing options...
St1ngr4y Posted January 31, 2015 Share Posted January 31, 2015 This image shows three faults which are present in the editor of v1.60 Rev 1. 1. The first line of the program cannot be changed - if you type something in place of "message here" or change the duration from 5 to something else, then move away to another line of the program, this first line then reverts to its original contants.2. I had used the up arrow to move line 328 up by one line. In doing so, its Resource icon changed from a Program command to a Locomotive.3. Before the upward line move described in (2), I had tried to amend the target of the chain command of line 162 (which at the time was the third line down). Having selected the new target file from the File Open Dialog, the editor placed the selected file name into the Run column and left the instruction column unchanged. /media/tinymce_upload/Editor_faults.png I have submitted a Help Request through the system this morning to cover these faults.Ray Link to comment Share on other sites More sharing options...
St1ngr4y Posted January 31, 2015 Share Posted January 31, 2015 I have just reported another program editor fault new to 1.60 Rev 1. The points dropdown lists giving the addresses of the points available in the Track Diagram is empty on every points command in a program.Ray Link to comment Share on other sites More sharing options...
GWR Greg Posted January 31, 2015 Author Share Posted January 31, 2015 The same for me v1.60r1 no points in drop down list. Link to comment Share on other sites More sharing options...
96RAF Posted January 31, 2015 Share Posted January 31, 2015 Groundhog Day...Reminds me of putting typing into my boss's secretary, who poor soul was dyslexic (yes she was a dyslexic blonde - you wonder how she could have been hired as a secretary in the first place). Anything you put in was corrected, but came out with other stuff that WAS previously OK but now incorrect.Any blondes in HRMS ???I bet this doesn't get past Adam - for long. Link to comment Share on other sites More sharing options...
HornbyRailMasterSupport Posted January 31, 2015 Share Posted January 31, 2015 You should find that the listing of points in program editing, along with a couple of other minor issues, have been resolved if you download and install from www.powerpos.com/rail-master/rm_setup.exe Link to comment Share on other sites More sharing options...
GWR Greg Posted January 31, 2015 Author Share Posted January 31, 2015 Yes listing of points resolved but not message issue. Link to comment Share on other sites More sharing options...
