mbidgo Posted February 4, 2015 Share Posted February 4, 2015 I have two shunters that I wish to use as a pair but they have very different motor characteristics.If I set them up as a double header, moving one slider on the screen moves both controllers to identical speed values and one loco drags the other along.I make full use of programs / schedules to run my layout.I set up both locos with 'cruise speeds' that perfecty match each other (25 and 18) and mark them as double headers. If I use a program to move either loco, only the specific one indicated moves its slider and the other one stays a zero. Result being - One drags the other along.Is this a known limitation of the current Release. Link to comment Share on other sites More sharing options...
mbidgo Posted February 4, 2015 Author Share Posted February 4, 2015 Updated version of the above.I have two shunters that I wish to use as a pair but they have very different motor characteristics.I make full use of programs / schedules to run my layout.I set up both locos with 'cruise speeds' that perfecty match each other on the track (25 and 18) and mark them as a double header. If I use a program to move either loco at cruise speed, only the specific one indicated moves its slider to its cruise speed and the other one stays a zero. Result being - One drags the other along.If I press the 'cruise button' on one loco control screen, both loco controllers move to the cruise speed value of that selected loco. Result being - One loco drags the other along.Is this a known limitation of program control in the current Release.I could set up a cruise speed command for each loco 0.5 secs apart but that seems messy. Link to comment Share on other sites More sharing options...
