Chalky1707817905 Posted February 15, 2015 Share Posted February 15, 2015 Is it possible to save the track layout made with TM to RM or do we have to make a complete new layout Link to comment Share on other sites More sharing options...
Fishmanoz Posted February 15, 2015 Share Posted February 15, 2015 Unfortunately you can't chalky. The actual layout produced by TM is quite different to the conceptual layout you make up in RM. The RM layout doesn't have anywhere near the range of different track pieces and points that are needed to design an actual layout in TM, nor does it need to. Once you start, you'll find it takes only a little time to design you RM layout, either from scratch of by starting with and modifying one of the layouts already supplied. If you modify one, don't forget to save it to a new name or you'll lose it when RM upgrades. Link to comment Share on other sites More sharing options...
96RAF Posted February 21, 2015 Share Posted February 21, 2015 A shame really Fishy as I'm sure many people would start by concepting a layout in TM by piece parts then want to import this into RM. SCARM has the facility for both actual piece part track design and 'lego' schematic design so the concept is possible. Maybe Hornby is missing a trick here. By that I mean you draw up your layout in accurate piece part form then press a convert button to have it transform to RM schematic form so you can import it into RM and populate such areas as points, signals, etc I may have had a good idea here for once. Link to comment Share on other sites More sharing options...
Fishmanoz Posted February 21, 2015 Share Posted February 21, 2015 Possibly, see my answer in your Concept post. Link to comment Share on other sites More sharing options...
ModelerXYZ Posted February 21, 2015 Share Posted February 21, 2015 It would be good to have that facility, especially if you are planning on running DCC with e-link or an elite and using RM. another feature would be a wiring diagram for DC as well.XYZ Link to comment Share on other sites More sharing options...
HornbyRailMasterSupport Posted February 23, 2015 Share Posted February 23, 2015 We are looking at these possibilities however it is very complex indeed to create an algorithm to convert a precise plan to the MIMIC, non-scale plan used in RailMaster. When you consider that even a complex plan takes under an hour to design in RailMaster this should not be a pressing issue, although desirable. Link to comment Share on other sites More sharing options...
