geoffb41 Posted February 17, 2015 Share Posted February 17, 2015 have with one of my points and railmaster.If i change it's direction thru railmaster it changes it then changes it by itself 2 or 3 times.if i change it just using the elite it works finehave removed it in track plan and put it back in but still does the samehave over 20 points and it's only this one thats a problemas it works perfectly using the elite shouldn't be the decoder or the point motor it must be a RM issue.thought removing it and putting it back would fix it but it hasn't appreciate any advicegeoff Link to comment Share on other sites More sharing options...
96RAF Posted February 17, 2015 Share Posted February 17, 2015 geoffIn the manual it tells you that RM sends a point command twice as a precaution to ensure a sticky point is activated.As this is the only dodgy point right click on it on your plan in design mode and see if there are any other actions/commands linked to it by mistake.People have reported certain addresses can cause problems and there have been instances of points playing up, so you should send a report to RM through the built in reporting system.This will send all the necessary files to HRMS for their attention. You will get an automatic response then shortly an answer to you question. Support is very good and usually replies in a very short timescale. Link to comment Share on other sites More sharing options...
St1ngr4y Posted February 17, 2015 Share Posted February 17, 2015 Hi Geoff,Is there any chance you have two points in your track plan defined with the same address?Ray Link to comment Share on other sites More sharing options...
geoffb41 Posted February 17, 2015 Author Share Posted February 17, 2015 Hi Geoff,Is there any chance you have two points in your track plan defined with the same address?RayThanks Raydid have two with the same no. and looks like it fixed itgeoff Link to comment Share on other sites More sharing options...
96RAF Posted February 18, 2015 Share Posted February 18, 2015 Hi Geoff,Is there any chance you have two points in your track plan defined with the same address?RayThanks Raydid have two with the same no. and looks like it fixed itgeoff So what you thought was the one changing a few times was actually two of them changing twice each.At least the problem is solved and you can press on. Link to comment Share on other sites More sharing options...
