victorrichard Posted February 26, 2015 Share Posted February 26, 2015 Hi Do you have to have the e-link to purchase the pro pack.I only have the elite will the pro pack work with the elite only.Vic Link to comment Share on other sites More sharing options...
Fishmanoz Posted February 26, 2015 Share Posted February 26, 2015 Hi Vic, no you don't. You can think of Elite or eLink as simply being interfaces between RM and your track. They do not affect the way RM works. There is a minor exception and that is due to the different data rate that Elite and eLink can handle. Link to comment Share on other sites More sharing options...
victorrichard Posted February 26, 2015 Author Share Posted February 26, 2015 HiThanks will goahead and spend some hard earned cash.vic Link to comment Share on other sites More sharing options...
2e0dtoeric Posted February 26, 2015 Share Posted February 26, 2015 Again - this should really be in the DCC threads!Another one to move! Link to comment Share on other sites More sharing options...
RDS Posted February 26, 2015 Share Posted February 26, 2015 I would say, better in the RailMaster section. Link to comment Share on other sites More sharing options...
antonello_antonello Posted March 31, 2015 Share Posted March 31, 2015 ciao io ho rail master e volevo aggiungere pro ,mi cambia ? in meglio ?? Link to comment Share on other sites More sharing options...
Chrissaf Posted March 31, 2015 Share Posted March 31, 2015 ciao io ho rail master e volevo aggiungere pro ,mi cambia ? in meglio ?? Translation:hello I rail master and I wanted to add pro, I change? for the better ??.ReplyThis was answered in your other post.Translation:Questo è stato risposto in altro post..https://www.hornby.com/uk-en/forum/railmaster-pro/?p=1 Link to comment Share on other sites More sharing options...
TonyO Posted October 1, 2015 Share Posted October 1, 2015 Firstly, the good news; the new Railmaster/Elink firmware versions have allowed me to use RailMaster on my new Toshiba laptop, updated to Windows 10. Now I have a question; having purchased the Pro Pack, I have activated it and got confirmation while doing it but nothing seems to have happened (no changes to Layout Designer etc). How do I know that the activation went OK? Would the code stay on the Loco Detection tab? Link to comment Share on other sites More sharing options...
TonyO Posted October 1, 2015 Share Posted October 1, 2015 Me again! I realize both activation codes are under Help but Pro Pack activation still didn't do anything although when I try again it says "already activated". How do I download all the new stuff? Link to comment Share on other sites More sharing options...
Nick_ Posted October 1, 2015 Share Posted October 1, 2015 You shouldn't have to do anything other than stop and restart Railmaster. On startup you should see a new startup banner saying Pro So you know it's active Link to comment Share on other sites More sharing options...
WilliamDavid Posted October 1, 2015 Share Posted October 1, 2015 After entering the Activation code in the System Settings/Loco Detection window, you have to close it down and restart to activate Pro.On starting up you should see a Propack window. Link to comment Share on other sites More sharing options...
mallone Posted October 1, 2015 Share Posted October 1, 2015 Hi Tony0... The most obvious thing to show that you have Pro will be yellow and black chevrons on you home page at th top right and bottom right of your track plan. Theses are to minimise the task bars so as to make the track plan area larger. Link to comment Share on other sites More sharing options...
TonyO Posted October 5, 2015 Share Posted October 5, 2015 Thank you, Nick, William and Mallone. I obviously haven't yet installed the pack although I've activated it. I'm in touch with support who suggest the problem might be because I registered the base product using different details. I will keep in touch! Link to comment Share on other sites More sharing options...
TonyO Posted October 13, 2015 Share Posted October 13, 2015 Just to let you know that RM support logged into my PC and fixed my problem - it turned out to be a bug that no-one else had experienced. Thank you support - most helpful and efficient! So now I'm playing with the extra facilities! Link to comment Share on other sites More sharing options...
RDS Posted October 17, 2015 Share Posted October 17, 2015 ... yellow and black chevrons ...Is there a command in the .ini file to ensure that the track plan is always as large as possible, without having to click the chevron each time.Also, is it possible to remove either completely or using the .ini file, the mouse icon (bottom left of screen) and touch screen icon (top left of screen) Link to comment Share on other sites More sharing options...
96RAF Posted October 17, 2015 Share Posted October 17, 2015 You can definitely turn off the mouse icon in the .ini file, but I think you are stuck with the others.I tried a search of the forums for turning off the mouse but came up zilch. Try 0 or 1 against the mouse line. Link to comment Share on other sites More sharing options...
RDS Posted October 17, 2015 Share Posted October 17, 2015 Thanks RAF96, I added 'Enable Mouse = 0' to my .ini file and the mouse icon has gone. You may remember a couple of weeks ago, I raised a new thread regarding the index in the RailMaster manual. Having found the .ini file details by accident in the v1.62 manual on page 32, I looked through the index to see what was listed as being on page 32. I found 'RailMaster .ini file'. No wonder I did not find it previously as it was listed under R, for RailMaster. I was disappointed with the quantity of responses to my request for more entries in the index ( 1 only, yours!) as I still maintain a good index is essential in a reference book, because that is what the manual is. The more entries there are in the index, the more useful it becomes. Maybe it is time to bring that thread to the top again. Link to comment Share on other sites More sharing options...
96RAF Posted October 17, 2015 Share Posted October 17, 2015 The more entries there are in the index, the more useful it becomes. Maybe it is time to bring that thread to the top again. Agreed RDS - a poor Index is a bit like me trying to find someone in my Contacts list which has lots of long Greek Surnames and I only know someone as first name Costas or Nicos. Link to comment Share on other sites More sharing options...
Yelrow Posted October 17, 2015 Share Posted October 17, 2015 RAF, if you ignore the talking to your train bit, which i think is extremely gimmickly, and will lead to the arrival of men wearing white coats. is there £30 x worth of advantage to make the purchase cost effective. I say this, with my bank managers hat on. john Link to comment Share on other sites More sharing options...
96RAF Posted October 17, 2015 Share Posted October 17, 2015 @JohnNo - not in my opinion and the voice control is just as dodgy in RM as it was when it when I was testing it for an independant 3-4 years ago. You get to print a few things, sort stuff in various orders and do things with detection stuff we don't have yet, so , pas de value... Link to comment Share on other sites More sharing options...
Yelrow Posted October 17, 2015 Share Posted October 17, 2015 Begs the question then ??????. john Link to comment Share on other sites More sharing options...
Fishmanoz Posted October 17, 2015 Share Posted October 17, 2015 A few bits of printing and sorting? The list looks like this: • Voice control of locos, points, signals and accessories using natural speech• Quick data backup system (locos, plans and programs) to secure your data• Saving of current multiple headers for use the next time the program starts• Ability to switch other points or signals when firing any point or signal• Ability to run programs when clicking any point or signal• Ability to run programs from the floating button bar• Additional positionable buttons in track design to run programs• Larger minimize, maximize and close buttons for touch screen users• Printing of loco CVs lists• Setting the order of points and signals settings on start-up• Multi aspect colour light signals including flashing light signals• Point and signal IDs shown at all zoom levels on main window• Support for all Train-Tech colour light signals• 45 degree point elements on Track Design screen• Printing of track plan designs on a monochrome or colour printer• Setting up of ‘smart’ double slip, single slip and three way points• Automatic loco profiling system using optional Loco Detection• Immediate testing of points and signals in track design mode• Loco decoder reset function in CVs programming window• Printing lists of timed schedules• Facility to delete track plans within the track design window• Facility to delete programs within the program editing window• Reverse loco setting in loco settings window• Ability to reverse selected locos within a multiple header• Collapsible top and bottom window sections to increase track plan view• Second large pop-up loco controller• Saving the selected track plan zoom setting when restarting• Facility to email user if a short circuit or error stops programs Looks to me like voice control is one of 28 items and certainly not what I bought it for. There's some pretty powerful stuff in there too, particularly point and signal control and more across a wide range of RM features. But everyone will form their own opinion on whether to trouble the bank manager.. Link to comment Share on other sites More sharing options...
96RAF Posted October 17, 2015 Share Posted October 17, 2015 I really like the ability to have an email arrive telling me the layout I am standing in front of has gone belly up. In truth most of those 28 very desirable items listed are of no interest to me yet - signals, loco detection, double slips, etc but there are obviously people out there to whom they are. Some stuff is handy but doesn't go far enough - double expanded throttles, why not as many as you want and scalable so you can fit a row somewhere on screen. I could do that in the development software I was working on previously mentioned. Some stuff is essentialy basic core stuff and doesn't work properly yet - corrupt functions listings, loco photos disappearing or swapping by themselves. Don't think I am knocking RM, I'm not, as it is just what I am looking for to run my trains, but it still has many glitches whether you have Pro or Am Pack. I know and appreciate that HRMS provide a good support service, even if they have a nutty configuration control method.. Link to comment Share on other sites More sharing options...
Yelrow Posted October 17, 2015 Share Posted October 17, 2015 Fishy, sorry, as they say in the car auction, Take it out, Not Sold. Nothing in there, warrants my hard earned cash, at the moment. john Link to comment Share on other sites More sharing options...
RDS Posted October 17, 2015 Share Posted October 17, 2015 ... warrants my hard earned cash ...Being able to get one point to set another point was enough for me, in fact I am seriously considering Pro Pack for my Networked version as well. Link to comment Share on other sites More sharing options...
