mdasseville Posted March 3, 2015 Share Posted March 3, 2015 Hi will the select controler work with railmaster software? Mike Link to comment Share on other sites More sharing options...
RDS Posted March 3, 2015 Share Posted March 3, 2015 Hi will the select controler work with railmaster software?Hi MikeNo, you need either e-link or the Elite Controller. Link to comment Share on other sites More sharing options...
mdasseville Posted March 4, 2015 Author Share Posted March 4, 2015 Hi Thanks for your mail, The reason i ask as in the System setting of railmaster Controller can be Elink/Elite or Selectso i just wondered if anyone has tried? Mike Link to comment Share on other sites More sharing options...
mdasseville Posted March 4, 2015 Author Share Posted March 4, 2015 Hi will the select controler work with railmaster software?Hi MikeNo, you need either e-link or the Elite Controller.Hi Thanks for your mail, The reason i ask as in the System setting of railmaster Controller can be Elink/Elite or Selectso i just wondered if anyone has tried? Mike Link to comment Share on other sites More sharing options...
Yelrow Posted March 4, 2015 Share Posted March 4, 2015 I think thats meant to be read as elite with select as walkabout, joined to elite with special cable. I may be wrong, but thats my understanding. john Link to comment Share on other sites More sharing options...
96RAF Posted March 4, 2015 Share Posted March 4, 2015 To work with RM the controller has to connect to a pc/laptop via a USB cble and the Select doesn't have a port to plug one in. The eLink does and the Elite does and the Elite can hook up a Select as a Walkabout so thats the only way you can use a Select with RM.. You just beat me to it JohnRob Link to comment Share on other sites More sharing options...
mdasseville Posted March 4, 2015 Author Share Posted March 4, 2015 Many Thanks Rob/John Mike Link to comment Share on other sites More sharing options...
Fishmanoz Posted March 4, 2015 Share Posted March 4, 2015 Even if you have Select as a Walkabout on your Elite, it will be the Elite acting as the interface from RM to track, not Select. You won't be able to configure RM setup to show the Select, only Elite. Link to comment Share on other sites More sharing options...
