52train Posted March 13, 2015 Share Posted March 13, 2015 Got new laptop down loaded windows 7 got new rail master yesturday it's on the laptop but when I fill out the info including the Activation Key, I getUnable to enter resource-0Any ideas fill free to join in Link to comment Share on other sites More sharing options...
Yelrow Posted March 13, 2015 Share Posted March 13, 2015 Can you see RM on your screen, if so, you could email Help desk from screen. I have no idea what resource 0, is. The other thing you could try, is downloading from Powerpro plus, but far cleverer people than me, which is not difficult, will be along shortly to advise. I have a phone no,you can ring, if all else fails. john Link to comment Share on other sites More sharing options...
HornbyRailMasterSupport Posted March 13, 2015 Share Posted March 13, 2015 First try downloading and installing afresh from www.powerpos.com/rail-master/rm_setup.exe then try activating again. Link to comment Share on other sites More sharing options...
96RAF Posted March 13, 2015 Share Posted March 13, 2015 And don't forget to run it all with Admin rights 52T. Link to comment Share on other sites More sharing options...
Yelrow Posted March 13, 2015 Share Posted March 13, 2015 Gosh, i am cleverer, than i gave myself credit for, Gold Star, thank you, hornby support. Nice for me to be on right track, fo once. john Link to comment Share on other sites More sharing options...
52train Posted March 13, 2015 Author Share Posted March 13, 2015 Me again I have been trying to get my rail master to work but no joy any thoughts Link to comment Share on other sites More sharing options...
Yelrow Posted March 13, 2015 Share Posted March 13, 2015 52 Train, hi, did you do as Hornby Railmaster Support, suggested, They are the experts, to whom we all bow.If you have done as they ask, the only other question i have, is who is your Anti virus/ firewall with. john Link to comment Share on other sites More sharing options...
52train Posted March 13, 2015 Author Share Posted March 13, 2015 I turned it off when I was trying it Link to comment Share on other sites More sharing options...
Yelrow Posted March 13, 2015 Share Posted March 13, 2015 Did you succeed with download from powerpos. If, what did you get. john Link to comment Share on other sites More sharing options...
Yelrow Posted March 13, 2015 Share Posted March 13, 2015 Are you using an elink to connect to DCC, if so, there is a connection sequence. come back, and i will give you it. john Link to comment Share on other sites More sharing options...
Fishmanoz Posted March 13, 2015 Share Posted March 13, 2015 52, May I suggest you get out of this thread back to the RM forum and at the top you will find 2 sticky locked threads. The first takes you to a separate site which has excellent instructions on getting going with RM. The second contains a number of posts with similar detail, including yelrow's start-up sequence. Following through the suggestions from either source should find and solve your problems. Link to comment Share on other sites More sharing options...
52train Posted March 22, 2015 Author Share Posted March 22, 2015 Ok now I know Some has check every thing I have done and threr is a probleme, sent info of to hornby and will wait and see stay tuned. Link to comment Share on other sites More sharing options...
Chrissaf Posted March 22, 2015 Share Posted March 22, 2015 You say you tried activation with your AV disabled. Fine. But have you also added a RailMaster exception to your Firewall. See instructions in 'security.pdf' installed in your Railmaster program folder. Also, as using Windows 7, make sure that when you originally ran the 'rm_setup.exe' installer, that you 'right clicked' the setup file and chose 'run as administrator'.If you didn't 'run as administrator' you will need to uninstall RM and re-install again making sure you 'run as administrator' on the re-install. Link to comment Share on other sites More sharing options...
52train Posted March 22, 2015 Author Share Posted March 22, 2015 Yes the fire wall has been done correctly, Aprently it would not be the first time the activation key was duplicated or even wrong all to geth, lets what happens ? Link to comment Share on other sites More sharing options...
Fishmanoz Posted March 22, 2015 Share Posted March 22, 2015 Chris and 52, it is not necessary to reinstall to ensure it is Run as Administrator. All you have to do is right click on the Desktop icon, select Properties, then Compatibility tab and tick the Administrator box. And once you have checked that to make sure, there should be no need to do it again, even when installing upgrades. Link to comment Share on other sites More sharing options...
