Robespierre Posted March 20, 2015 Share Posted March 20, 2015 Ok, so I had a downer on approaching Railmaster setup/installation , mostly because of comment on here.But I got it to work, with minimal effort Link to comment Share on other sites More sharing options...
Robespierre Posted March 20, 2015 Author Share Posted March 20, 2015 Oops, some of my post has gone missing, anyway.......Only a few little things to sort along the way, mostly around firewalls and admin access ( all covered well by the Hornby docs )Just one question; what is the point of adding your circuit design? Link to comment Share on other sites More sharing options...
Chrissaf Posted March 20, 2015 Share Posted March 20, 2015 As you have found out. In the main, it is only when things go wrong, do the problems end up being aired on here. For the vast majority, the installation of RM goes without a hitch..Not sure what you mean by "Just one question; what is the point of adding your circuit design?". Do you mean "what is the point of adding your track design?".If you do mean 'track design'. There is no point at all. Unless that is, you are intending to control a number of accessories via RM. For example, points, signals, turntable etc. In that scenario, you can add control buttons for those accessories onto your track design plan and operate them by pointing and clicking. For which you will need suitable accessory decoders.. Link to comment Share on other sites More sharing options...
