Hinchsters Posted March 25, 2015 Share Posted March 25, 2015 Hi guys, Finally installed Railmaster and got it up and running.I'm just in the process of setting up the trackplan and as part of that adding the crossovers and points.My question is, can Railmaster use Accessory Decoders that have already been configured with individual port numbers using the Elite or do they need to be reconfigured using Railmaster? Can't seem to find anything in the manual to say one way or the other. Cheers!! Duncan Link to comment Share on other sites More sharing options...
RDS Posted March 25, 2015 Share Posted March 25, 2015 Hi DuncanRailMaster can use Decoders that were set up in the Elite. I have some ESU Switchpilot Point Decoders that I set up on my Elite but then used the id information for them in RailMaster and they can now be operated from RailMaster Link to comment Share on other sites More sharing options...
Hinchsters Posted March 25, 2015 Author Share Posted March 25, 2015 OK great.Many thanks for the response. I presume you just need to tell Railmaster the port number for each decoder? Cheers Duncan Link to comment Share on other sites More sharing options...
RDS Posted March 25, 2015 Share Posted March 25, 2015 Yes, that's right. It would be really clever if it could work that out for itself! Link to comment Share on other sites More sharing options...
Fishmanoz Posted March 25, 2015 Share Posted March 25, 2015 I think you only need to tell/setup RM with point numbers to match your already programmed decoder ports and you should be up and running Once your wiring is done. Link to comment Share on other sites More sharing options...
