antonello_antonello Posted March 26, 2015 Share Posted March 26, 2015 ciao ragazzi ,ho un problema quando devo salvare delle voci nel programma nuovo che sto facendo ,(quando gli do salva ) mi cancella altre voci le riscrivo ,mi salva le ultime ma mi cancella delle altre chi mi sa aiutare?? grazie in anticipo Link to comment Share on other sites More sharing options...
PJ_model_trains Posted March 26, 2015 Share Posted March 26, 2015 Hello can you speak English?Ciao puoi parlare inglese? I think this says...Hi guys ,i have a problem when I save the entries in new program that I'm doing , (when do save ) i erase other items the riscrivo ,save me the latest but i delete the other who i know help? Thanks in advance http://www.freetranslation.com/ Link to comment Share on other sites More sharing options...
St1ngr4y Posted March 26, 2015 Share Posted March 26, 2015 The Google translator came up with something similar... hello guys, i have a problem when I have to save the items in the new program I'm doing, (when they do save) I delete other items the rewrite, saves me the latest but I delete the others who I know to help ?? thanks in advance Still don't understand it :-) There's a challenge for the website - an alternative language input facility !!!Ray Link to comment Share on other sites More sharing options...
tony_forward Posted March 27, 2015 Share Posted March 27, 2015 Could Antonello perhaps mean that when he saves something that he has altered - a plan or program perhaps - when an update comes along his efforts are overwritten?ie, he should be saving altered programs with a new file name - amending for example one of the Hornby plans to suit his needs and resaving it with the same file name would mean he loses it after an update...Per Antonello:Antonello potrebbe forse significare che quando salva una cosa che ha cambiato - di un piano o di un programma forse - quando un aggiornamento viene avanti i suoi sforzi vengono sovrascritti? cioè, egli dovrebbe essere il risparmio pro alterato Link to comment Share on other sites More sharing options...
Teedoubleudee Posted March 27, 2015 Share Posted March 27, 2015 Could Antonello perhaps mean that when he saves something that he has altered - a plan or program perhaps - when an update comes along his efforts are overwritten?ie, he should be saving altered programs with a new file name - amending for example one of the Hornby plans to suit his needs and resaving it with the same file name would mean he loses it after an update...Per Antonello:Antonello potrebbe forse significare che quando salva una cosa che ha cambiato - di un piano o di un programma forse - quando un aggiornamento viene avanti i suoi sforzi vengono sovrascritti? cioè, egli dovrebbe essere il risparmio pro alterato Good point Tony, same thing happened to me till I twigged what happened. Link to comment Share on other sites More sharing options...
antonello_antonello Posted March 28, 2015 Author Share Posted March 28, 2015 ciao tony come hai risolto il tuo problema ?? Link to comment Share on other sites More sharing options...
HornbyRailMasterSupport Posted March 28, 2015 Share Posted March 28, 2015 [English]RailMaster 1.61 revision 2 (from www.powerpos.com/rail-master/rm_setup.exe) now contains a warning message when one of the default plans is saved under the same name. This will prevent an altered track plan from being overwritten when a new RailMaster update is installed.[italiano]RailMaster 1.61 revisione 2 (da www.powerpos.com/rail-master/rm_setup.exe) ora contiene un messaggio di avviso quando uno dei piani predefiniti viene salvato con lo stesso nome. Questo consentirà di evitare un piano di pista modificati vengano sovrascritti quando viene installato un nuovo aggiornamento RailMaster. Link to comment Share on other sites More sharing options...
tony_forward Posted March 28, 2015 Share Posted March 28, 2015 ciao tony come hai risolto il tuo problema ??ITALIAN Credo Hornby ha risposto a voi in italiano, se la loro risposta doen't aiuto, mandate una mail a loro direttamente dall'interno del programma RailMaster. Ciao, Link to comment Share on other sites More sharing options...
caponord Posted January 19, 2016 Share Posted January 19, 2016 ciao ragazzi ,ho un problema quando devo salvare delle voci nel programma nuovo che sto facendo ,(quando gli do salva ) mi cancella altre voci le riscrivo ,mi salva le ultime ma mi cancella delle altre chi mi sa aiutare?? grazie in anticipoCiao, antonello, ho anch'io lo stesso problema, tu l'hai risolto? se si come?Grazie in anticipoCiao. Link to comment Share on other sites More sharing options...
