Yelrow Posted March 29, 2015 Share Posted March 29, 2015 hi, went to run P2 con, and A4, with locksound, today, and whilst locos are fine, no sound. I am now using Elite only with RM, and clicking on sound on laptop screen. Do i have to co-ordinate both, or put functions in Elite to make sound work. Cannot think they have both failed at same time. Class 37, TTS, is fine. Any help to lower stress levels, appreciated. Elite is set as controller A, and sounds are enabled. thanks. john Link to comment Share on other sites More sharing options...
PJR_slo Posted March 29, 2015 Share Posted March 29, 2015 Hi John When using RM, both the Elite and E-link simply pass the commands from RM to the locos. There is absolutely no need to set anything on the Elite. However, have you tried using the function buttons on the Elite? If they don't work, then there is definately something wrong. If they do, then I would try restarting both Elite and PC and if the problem is still present, they it may be that you will need to reset the Elite. You could also try with the e-link to see if that works. Peter Link to comment Share on other sites More sharing options...
