Adamml5 Posted March 31, 2015 Share Posted March 31, 2015 hi I've have had an issue where when I click on a program via a set floating button I get an error message, (unable to find program 2, 6) Has anybody else seen this happen? It worked fine when it was first set but then the next day I had the error message. The program works fine if started from the program bar at the top of the screenThe program only sets the scale clock to a set time.Thanks Link to comment Share on other sites More sharing options...
St1ngr4y Posted March 31, 2015 Share Posted March 31, 2015 hi I've have had an issue where when I click on a program via a set floating button I get an error message, (unable to find program 2, 6) Has anybody else seen this happen? It worked fine when it was first set but then the next day I had the error message. The program works fine if started from the program bar at the top of the screenThe program only sets the scale clock to a set time.ThanksI had a similar problem with sounds assigned to buttons. They worked at first, then the name of the sound file became corrupted, so they stopped working. Have a look (using Notepad) at the file called ProgButtons.dat in the RM folder.Ray Link to comment Share on other sites More sharing options...
Adamml5 Posted March 31, 2015 Author Share Posted March 31, 2015 hi I've have had an issue where when I click on a program via a set floating button I get an error message, (unable to find program 2, 6) Has anybody else seen this happen? It worked fine when it was first set but then the next day I had the error message. The program works fine if started from the program bar at the top of the screenThe program only sets the scale clock to a set time.ThanksI had a similar problem with sounds assigned to buttons. They worked at first, then the name of the sound file became corrupted, so they stopped working. Have a look (using Notepad) at the file called ProgButtons.dat in the RM folder.RayThanks Ray ill have a look, did you email HRMS regarding this? Link to comment Share on other sites More sharing options...
St1ngr4y Posted March 31, 2015 Share Posted March 31, 2015 hi I've have had an issue where when I click on a program via a set floating button I get an error message, (unable to find program 2, 6) Has anybody else seen this happen? It worked fine when it was first set but then the next day I had the error message. The program works fine if started from the program bar at the top of the screenThe program only sets the scale clock to a set time.ThanksI had a similar problem with sounds assigned to buttons. They worked at first, then the name of the sound file became corrupted, so they stopped working. Have a look (using Notepad) at the file called ProgButtons.dat in the RM folder.RayThanks Ray ill have a look, did you email HRMS regarding this?To be honest, I can't remember whether I did or not.Ray Link to comment Share on other sites More sharing options...
