Eamesey Posted April 5, 2015 Share Posted April 5, 2015 hi tried reading cv values in rm pro pack, unfortunately it does no do it, requestors come up saying is track connect dcc? soundtraxx tsunami and hornby decoders tried to know availregards and thanksstephen Link to comment Share on other sites More sharing options...
Nick_ Posted April 5, 2015 Share Posted April 5, 2015 Are you using a programming track connected to the 'prog' output of your E-link? I don't think you can read cvs if you are connected to the main track output Link to comment Share on other sites More sharing options...
PJ_model_trains Posted April 5, 2015 Share Posted April 5, 2015 HiYou can't read cv's from the main track.As Nick says, you need a piece of track, not connected to the main track, just for reading and writing cv'sThis short piece of track needs a power connector to the track and connecting to the 'prog' outputs on your elink.It is possible to use an isolated section on the main track but the above method is the simplest.PJ Link to comment Share on other sites More sharing options...
Fishmanoz Posted April 6, 2015 Share Posted April 6, 2015 Hi Eamesey, you've told us very little about your setup and whether it is up and running correctly except for reading CVs. Can I suggest you look at either the first or second thread in the forum and follow it through to make sure your basic setup is working. Once that is ok, the advice from Nick and PJ should get you to reading CVs. Link to comment Share on other sites More sharing options...
