GWR Greg Posted April 8, 2015 Share Posted April 8, 2015 I have a situation where for no reason I can see elink stops responding to rail masterlaptop. The RM screen show change to loco speed or direction, points show as changed but nothing is happening on layout. After a while elink seems to wake up and actions previous commands then works okay again. Anyone know what is going on and how to stop it happening? Link to comment Share on other sites More sharing options...
Yelrow Posted April 8, 2015 Share Posted April 8, 2015 GWR, GREG, hi, had this a couple of times in the past, sorta, delayed action. I assumed, it might be in a loop, disconnected, re connected. Also, removed and replaced track feed, and elink wires. Twas fine, after that. You are lucky, you dont have power surges, as farmers, fire up, lord knows what. See if that helps. We had similar problem with TV, remote control, and was told, to take it out the loop, eg, as above. john Link to comment Share on other sites More sharing options...
St1ngr4y Posted April 8, 2015 Share Posted April 8, 2015 I have a situation where for no reason I can see elink stops responding to rail masterlaptop. The RM screen show change to loco speed or direction, points show as changed but nothing is happening on layout. After a while elink seems to wake up and actions previous commands then works okay again. Anyone know what is going on and how to stop it happening? Hi Greg,Is it possible there is some other software loaded on your pc which is bursting into life now and again, hogging the cpu, and preventing RM doing anything?Ray Link to comment Share on other sites More sharing options...
