4091Dudley Posted April 12, 2015 Share Posted April 12, 2015 HiDoes anyone know if its possible to directly download a SCARM design into railmaster?If you can't, would be useful functionality...Thanks! Link to comment Share on other sites More sharing options...
Chrissaf Posted April 12, 2015 Share Posted April 12, 2015 No you can't.I use SCARM as well as RM. Completely different software file specifications. Hornby can't even import track designs from its own Hornby Track Designer software into RM, so no chance it ever doing it with a piece of Freeware (SCARM). Link to comment Share on other sites More sharing options...
Fishmanoz Posted April 12, 2015 Share Posted April 12, 2015 You'll find that doing your own schematic design is very simple once you start, either by starting with one of the design in RM or from scratch. If you start with one in RM, make sure you save it to a new file name or you will lose it when you install an upgrade to the software. Link to comment Share on other sites More sharing options...
96RAF Posted April 13, 2015 Share Posted April 13, 2015 SCARM now has the facility to draw up an RM type schematic, so if you find SCARM easy to use then knock out your layout plan as a schematic and generate the general layout so devised into an RM schematic. Link to comment Share on other sites More sharing options...
Chrissaf Posted April 13, 2015 Share Posted April 13, 2015 Rob,."SCARM now has the facility to draw up an RM type schematic".Can you elaborate please. I have updated my SCARM installation to latest version 9.29 and can not find the feature you have eluded to..Chris Link to comment Share on other sites More sharing options...
Yelrow Posted April 13, 2015 Share Posted April 13, 2015 He has the cyprus version, i looked at it, but its all greek to me. john Link to comment Share on other sites More sharing options...
RB51 Posted April 13, 2015 Share Posted April 13, 2015 Hi Chris - > track library > objects > symbols > square tilesR- Link to comment Share on other sites More sharing options...
Chrissaf Posted April 13, 2015 Share Posted April 13, 2015 Thanks Roger, found them..Seems to me a lot of extra effort. You have to do the design twice. Once in SCARM, then again to replicate it in RM. Since the design process is so similar, makes sense to me to do it once directly in RM. The one advantage I do see for doing it in SCARM first, in SCARM you have a bigger canvas to work with. In RM you need to have a clear vision of what you are trying to create if a relatively large layout as the view of the available canvas can be limited. .Regards & Best WishesChris.EDIT: Having just given the SCARM version a try-out. I see you can create your design a lot faster in SCARM, there are less mouse moves and clicks and minimal need to drag and drop compared to RM. Link to comment Share on other sites More sharing options...
RB51 Posted April 13, 2015 Share Posted April 13, 2015 I think you are right Chris - for me not worth the effort for a mimic, say. Where I do think SCARM is helpful is:-1 Ensuring that what you want to do will fit your space available2 You can change your mind umpteen times at no cost3 You get a "parts list"R- Link to comment Share on other sites More sharing options...
Chrissaf Posted April 13, 2015 Share Posted April 13, 2015 Absolutely Roger,.I spent weeks visualising my layout in SCARM, with multiple reiterations before putting my hand in my pocket. The parts list was absolutely spot on. I built mine in flexi-track. After the last piece of track was laid I was left with six track offcuts none of which longer than 100mm. SCARM calculated everything down to the last millimetre..PS - As my design ideas grew, so did the size of the baseboard I would need to fulfill them. Would have been a near impossibility without SCARM. Originally working on a planned board size of 8ft x 4ft. Ended up being 8ft x 6ft 6". Link to comment Share on other sites More sharing options...
RB51 Posted April 13, 2015 Share Posted April 13, 2015 So, I'm not sure if Dudley is saying "Would it be useful...." or "It would be useful...." R- Link to comment Share on other sites More sharing options...
Chrissaf Posted April 13, 2015 Share Posted April 13, 2015 I think the latter, Roger Link to comment Share on other sites More sharing options...
4091Dudley Posted April 13, 2015 Author Share Posted April 13, 2015 Thanks all - much aporeviayed roger - definitely the latter. The idea you can drag and drop it in would save me timeon other points, I agree that scarm is very intuitive to use- particularly with set track - and had helped me get a workable design into my small space. Where I think it is weak is for a) adding Am electrics plan and b) seeing what scenery / buildings fit. I know you can do the latter but it's a bit fiddlyparts list also helpful. If I was a retailer with a major online presence, i'd have a link to somrthing like scarm to drive ordering. It was a bit of a pain to type each part into the search box and cross check. Link to comment Share on other sites More sharing options...
RB51 Posted April 14, 2015 Share Posted April 14, 2015 Hi Dudley - thanks, it's nice to be aporeviayed (I think). You have some great ideas there, maybe someone will do it one day as a result of reading this forum. Just not possible at the moment. R- Link to comment Share on other sites More sharing options...
96RAF Posted April 14, 2015 Share Posted April 14, 2015 One of the things I suggested to Mixy to add to SCARM was buildings such as Metcalfe kits. I provided him with dimensions and photos of my goods shed and he drew it with the intention of making like structures as menu items. The example was simplified without much detail but he was working on it. Link to comment Share on other sites More sharing options...
MetmanUK Posted April 14, 2015 Share Posted April 14, 2015 SCARM is for designing a layout whilst the schematic in RM is merely a representation of the significant parts of a layout. In most cases, one will only pay a passing resemblance to the other. In my case, with multiple levels and a shape that does not fit easily onto a screen, the resemblance is minimal. Link to comment Share on other sites More sharing options...
