the flying hodor Posted April 23, 2015 Share Posted April 23, 2015 hello alljust reading up on dcc and i am getting the hornby western master 2 morojust wonderd what they mean by a programming track do they just mean a section of track not connected to the main trackcould i just use say 2 long pieces of track and a dcc power track piece and i take it this is what i use for writing the cvs and changing loco numbers cheers dave Link to comment Share on other sites More sharing options...
RB51 Posted April 23, 2015 Share Posted April 23, 2015 Yes Dave - you have it in one. They dont have to be long pieces of track, just long enough to take your loco with a chip on board. But yes, you have it's purpose exactly. R- Link to comment Share on other sites More sharing options...
Yelrow Posted April 23, 2015 Share Posted April 23, 2015 Hodor, hi, When you buy a big set with more than one loco, they come from factory, all with CV 3, which means, you will need to change one of them to for example, no 4, to run them together without problems. Your controller comes with 2 sets terminels, one for Layout, one for prog track. black wires for prog track 2 pieces joined together is enough for prog track, which is totally seperate from layout. It is here, on prog track, where you place loco to change cv no. It is better to change both, once you have mastered technique, as next loco, you buy, will again be cv3, regardless of make. I would run both locos, seperately, to make sure they are perfect, before trying to change cv, for which, you may need our help, I did. john. Link to comment Share on other sites More sharing options...
the flying hodor Posted April 23, 2015 Author Share Posted April 23, 2015 Yes Dave - you have it in one. They dont have to be long pieces of track, just long enough to take your loco with a chip on board. But yes, you have it's purpose exactly. R-thanks for the help Link to comment Share on other sites More sharing options...
the flying hodor Posted April 23, 2015 Author Share Posted April 23, 2015 Hodor, hi, When you buy a big set with more than one loco, they come from factory, all with CV 3, which means, you will need to change one of them to for example, no 4, to run them together without problems. Your controller comes with 2 sets terminels, one for Layout, one for prog track. black wires for prog track 2 pieces joined together is enough for prog track, which is totally seperate from layout. It is here, on prog track, where you place loco to change cv no. It is better to change both, once you have mastered technique, as next loco, you buy, will again be cv3, regardless of make. I would run both locos, seperately, to make sure they are perfect, before trying to change cv, for which, you may need our help, I did. john.thanks for the info i am sure i will need more help later on lol Link to comment Share on other sites More sharing options...
Fishmanoz Posted April 23, 2015 Share Posted April 23, 2015 Just for clarity, it is loco IDs that you change. Yes, the IDs are held in CVs, and which CVs depends on whether you are using 2 (short) or 4 (long) IDs. But in the first instance, you don't need to know which CV, just use the changing ID instructions. And if you want to know more about setting up, read one of the 2 detailed help guides in the 2 threads at the top of this forum. Link to comment Share on other sites More sharing options...
